Moderator
![]() Join Date: Jun 2008
Tilt lower bearing removal
I just bought a Tilt steering column from a 1970 GM truck. I did a "search" here and found many posts on columns, but could not find one on this exact aspect: bearing removal.
When I turn the mast I can hear a grinding sound like there is dirt or metal bits in the lower bearing. I have ordered a new lower tilt bearing and plastic housing. But, how do you remove the bearing from the shaft (mast)? I know there is a metal clip and bearing retainer, but after those are removed, how does one proceed to remove the bearing from the shaft? I just don't want to mess anything up. Please enlighten me! ![]() Thanks! -Richard
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
Re: Tilt lower bearing removal
Hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Moderator
It does, thanks Dan!
However, how does one remove the lower bearing? Is there a special tool, or does one just wiggle, pry, and tap it off?
The bearing just slides off of the shaft but it helps to clean the shaft first with fine sand paper. Lube the shaft with a penetrant, also.
After that "wiggle, pry, and tap" it off. (I assume that you have the snap ring removed). Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 07-18-2008 at 09:21 PM. Reason: wording change |
![]() Join Date: Jul 2004
Just did one of these, our bearing was plenty rusty on the shaft, and the retainer was made of plastic. Soak it up with BB blaster, and wiggle, pry, tap !!!
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Moderator
Thanks guys! LOL!!! Yes, the snap ring is off. I'll give 'er a shot.
Tot Roddin'
I'm glad someone brought up this point, because I'm planning on rebuild the tilt column this summer. Good luck Richard!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Has anyone ever done a write up on a tilt rebuild?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Tot Roddin'
Not from what I've found on the board, but I think that it is definitely needed.
When I start the rebuild on my column I will have to catch a picture, and if no one has started one I will try my best to create one.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 07-19-2008 at 11:40 PM. |
Moderator
Well, that did the trick. I got the lower bearing off. Thanks! I did not need to remove the upper as it was fine. Besides, I am a visual learner and getting the top part of the column apart without pictures is not something I wanted to do if I didn't need to.
The bummer news is that the column that I am rebuilding I just bought off of eBay. The seller advertised it as "off of a 1970 Chevy Truck." So, I figure that I'll just use it and colapse that shaft as I have read. Is there a write up with pictures on colapsing the intermediate shaft at the plastic rivits? I would like to see for certain where and what I need to do the mod.
If the column you have is an original truck column, collapsing the shaft is not needed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Moderator
...oops, I meant to say that the seller advertised it as "off of a 1970 Chevy Truck." Howerver, it has the long shaft and it so it is a VAN column. Instead of dealing with sending it back and so on, I just figure that I'll just use it anyways and colapse that shaft as I have read somewhere. But pictures and a write up would definately be of help.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 07-20-2008 at 03:10 AM. |
#13 |
I just used a hammer with the shaft off the column & in a vise. Couple hits on the end on the shaft, & the plastic rivets give.
1997 GMC Sierra Ext 1965 Mustang |
#14 | |
Moderator
I have a couple questions in regaurds to getting the van column to work: 1. What about the neutral safety switch? Do I need to move its location? If so, do I need to cut a similar sized slot into the column sleeve? 2. Does the slined (van) steering shaft bolt right up (fit) the intermediate shaft on a truck? 3. Once the intermediate shaft is colapsed, and you have it all bolted back together, is there play or slop in the shaft? Should I re-drill and insert some bolts or screws where the old rivit holes were to tighten it up?
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 07-20-2008 at 02:09 PM. |
#15 |
454 MAKES IT ROAR
Here you go, these are the guys that helped me
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Thread Tools | |
Display Modes | |
