07-20-2008, 09:22 PM | #1 |
How to gain 3 inches in an afternoon
Get your minds out of the gutters, I'm talking about tubbing the rear.
So basically I'm going to be running 315/35/20s on the back of my pickup. Guess what, they won't fit with the stock wheel wells. So I set out to tub the wheel wells. The idea here is to add some extra width while maintaining the stock look. Hopefully you won't be able to tell unless you know exactly what you are looking for. Here is my progress. I first started by removing the wheel well. Of course the square holes didn't hold the bolts to prevent them from spinning, I cut a slot in them to hold them with a screwdriver, and that didn't work, so I cut the heads off of most of them. The two in the corner next to the fenders, I tack welded them and just took off the nut. Then I drew out the plan on the floor with a sharpie and then taped up some lines to cut along. The cross hatched area is the area to be removed. I had to do a little drilling and prying to get the floor off of the cross members that they're spot welded too. So here's what it looks like after being cut out: I cleaned up the cross members a little and sprayed a little spray paint in there while I had access to it. Then I cut out some sections of my parts truck bed. To fill in the missing space. After some cutting and grinding and a little bit of trial fitting, I got to tack welding all of the pieces in. Overall, this will gain me about 3 1/4 inches of extra tire space. I may also try modifying the the piece in the wheel well that connects the inner fender with the outer fender so I can really set the tires at the edge of the wheel well. For the wheel well themselves, I'm going to get new wheel wells and then splice in a section of the original wheel well (the originals are banged up a little. |
07-20-2008, 09:36 PM | #3 |
Re: How to gain 3 inches in an afternoon
looks good
07-20-2008, 10:07 PM | #4 |
Like a Rock!
Really??? I thought 295's were easy to fit?. What backspace are you running?
Ackattack- nice work!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
07-20-2008, 11:55 PM | #5 |
Tasty Cakes!
Nice work. I have a feeling this mod will be in my future.... geez I'm psychic!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
07-21-2008, 04:06 PM | #6 |
the will and desire take over,,, I also see my self doing this in the near future.
Good Job!! |
07-21-2008, 07:35 PM | #7 |
Big Block
Very nice work.
08-11-2008, 12:46 AM | #8 |
A little more progress tonight:
First I cut the wheel well in half and bolted them in place. Then I took my old wheel well and figured out what section of it I'd need to use, and cut that out. Then I slid it in place, and marked and cut it to fit in between the two halves of the "new" wheel well. Then started welding in the mid section. It was mis-aligned ever so slightly, so I had to make a few relief cuts to the everything to line up the way I wanted it to. Then I took out it out so I can finish up the welding (another day). I snapped a pic next to the stock one just for comparison. |
08-11-2008, 12:56 AM | #9 |
Official Site Guitar Shredder
Looks killer........Great job........
08-11-2008, 01:01 AM | #10 |
Built 4 Speed
looks very nice. Im sure final product. will be 10 fold.
.02 might want to remove paint before you finish up the welds.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
08-11-2008, 01:10 AM | #11 |
Old member
Cool mod. I have also thought about this. My tires rub just so slightly on the inside of the wheel well. Only when I hit a real bad pot hole though. Cool idea though.
08-11-2008, 02:06 AM | #12 |
Looking good man. Here are those pics we talked about at the meet:
08-11-2008, 02:16 AM | #13 |
PROJECT 7DEUCE
Yep I had to do that too... Looks good though..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-11-2008, 03:19 AM | #14 |
i like it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
08-11-2008, 10:28 AM | #15 |
Thanks for the pics, I tried searching for them, but couldn't find them.
08-11-2008, 10:51 AM | #16 |
great mod
08-11-2008, 12:54 PM | #17 |
VA72C10
Looks great...makes me want to go a little "meatier" in the rear
08-11-2008, 02:25 PM | #18 |
not trying to be a butt. Wouldnt it be simplier to just cut the two different tubs in the loactions to make one tub 3 inches wider? That way there is only one seam to weld.
not trying to offend you
72 LWB |
08-11-2008, 02:36 PM | #19 |
2 sets of wheel wells is how I did mine. However I will have A wood floor when complete. I elected to go 6" wider. You never know what I want to stuff under there in the future.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
08-11-2008, 02:47 PM | #20 | |
Also, my old wheel wells were dented up pretty good, so this worked out best for me. |
08-11-2008, 02:48 PM | #21 |
They look great, I am wating to see those meats stuffed under there!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
08-11-2008, 08:18 PM | #22 |
Nice work. I'm just about to dig into my first fleetside so I'm not very familiar with that inner piece yet. I'm much more familiar with the stepsides. Great work.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
08-11-2008, 09:01 PM | #23 |
kinda like mine with 33x18.5x15 on steel rallys w/ 10" bs
08-11-2008, 09:03 PM | #24 |
big fat tires...........
08-13-2008, 09:23 AM | #25 |
Nice work!
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
Thread Tools | |
Display Modes | |
