Old 07-24-2008, 11:01 PM   #1
84step
exhaust pick
Iam pretty sure I already know what everyones awnser is going to be but iam still a little curious. My question is which exhaust is better performance/sound and what do you guys all prefer flowmasters or glasspacks? I currently have glasspacks and am thinking of switching them out for 40 series but havent decided yet.
84step is offline   Reply With Quote
Old 07-24-2008, 11:11 PM   #2
BaddBusa2005
BaddBusa2005's Avatar
Re: exhaust pick
go with something different. moflasters over too over done. I would try spintech, slp, or even hooker aerochambers.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 07-24-2008, 11:35 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
Re: exhaust pick
A Flowmaster with catalytic converters and iron manifolds is overdone. There's countless V8 trucks that roll off the lot straight to the exhaust shop. It sounds awesome, but as said before it's almost too popular now.
Flowmasters with long tube headers and no catalytic converters is in my opinion, a very different sound than your usual brand-new-truck-with-a-Flowmaster sound. The best way I can describe it is you hear the full range of sound the motor produces, whereas iron manifolds and catalytic converters just leave you with a mellow low end rumble.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-24-2008, 11:41 PM   #4
Square84
I don't think these pills work
Square84's Avatar
Re: exhaust pick
i have 40 series flows and dont care for them because you can hear every single little sound your truck makes. i spend have my time driving with the stereo off asking what was that?it drives my wife crazy cause she says she didnt hear anything.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 07-24-2008, 11:54 PM   #5
ton*loc
ton*loc's Avatar
Re: exhaust pick
that is so funny i've been there a thousand times.
the answer is flowmaster's with long tube headers.
anybody who says anything else if a lair !!!!!
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 07-25-2008, 12:33 AM   #6
85SBC400
Re: exhaust pick
i currently have long tubes, no cats, 2ft glasspacks (looks like anyways) and straight out the back 2.5in pipe.
i'm going to get rid of the glasspacks and go with dynomax's race bullets turned down before the rear axle. i think that will sound killer with my 400 cam'd. and they were cheap at 39 bucks a piece.
but if i had the money i'd go with long tubes and the 40 series flows i think.
85SBC400 is offline   Reply With Quote
Old 07-25-2008, 10:12 AM   #7
blk81shrt
blk81shrt's Avatar
Re: exhaust pick
If you have a lopey enough cam, anything should sound good! I have heard mufflers with no baffles preform better, I think Magnaflow and Borla (??) have straight through designs with baffles around the inside only. Probably get the best performance, I dont know about sound though!
blk81shrt is offline   Reply With Quote
Old 07-25-2008, 10:29 AM   #8
jdurant
Re: exhaust pick
I use dynomax straight thrus on the buicks and my mustang. You're gonna be shocked at how quiet they are. I like the tone, they drone a little though. More raw than a 40 series, but quieter.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 07-25-2008, 10:33 AM   #9
gearhead1968
gearhead1968's Avatar
Re: exhaust pick
I have long tube headers, 2 1/2" Dual exhuast through an H-pipe, Magnaflow mufflers, and turndowns over the rearend. I love it!!! before I had exhuast manifolds that flowed into flowmasters and turn downs well before the rearend, it was way to loud, I could not even talk to anyone riding with me without yelling.
1976 C-10 shortbed 2wd (work in progress)
Mods:
Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier
http://www.cardomain.com/ride/3136537
gearhead1968 is offline   Reply With Quote
Old 07-25-2008, 03:00 PM   #10
BaddBusa2005
Re: exhaust pick
Magnaflow makes a nice muffler too.
edit: i have sbc lontubes and 3" custom exhaust that dumps before the axle that someone can have if they want it. It is off my truck from the 305
Old 07-25-2008, 03:13 PM   #11
Prerunner1982
Prerunner1982's Avatar
Re: exhaust pick
I had a set of long tube headers, dual 3" pipes and flowmasters with no cats dumped before the axle on my 82 with a stock 350. That thing sounded mean.... but resonated into the cab and you always had to have the radio turned up way too loud to even hear it and you couldnt carry on much of a conversation. I am still holding on to it though for my next pickup more or less because I already have it and that is money I wont have to spent. I would go with 2.5" pipes though.. IF I were to build a new exhaust system I would probably go with Hooker Aerochambers.
Before the flowmasters I had a single Magnaflow which wasnt bad at all, but I only had a single instead of dual so it may have sounded better in a dual setup. The Magnaflow is going on my Jeep.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 07-25-2008, 04:55 PM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
Re: exhaust pick
I quess I would ask---Do you want the most POPULAR or do you want to try something that is different or UNTRIED. I would call Flowmaster, Magnaflow, or Edelbrock for a brand overview. I talked to the suppliers when I built my stroker motor for my 84 SWB and put a 2 1/2" dual exhaust system on it, and I cannot say that the Flowmasters have done me wrong. The sound is good, the performance is great, and the quality is good. I went with the POPULAR because it is a good quality muffler. I will not go back to glasspacks and the lower cost Magnaflows cost me too much in replacement costrs on the daily driver truck. They rotted out every two years at about 21,000 miles a year. The Flowmasters have not done that. I replaced the Magnaflows on the DD with a Flowmaster and it is at 2 years and climbing for use.
piecesparts is offline   Reply With Quote
Old 07-25-2008, 06:50 PM   #13
chevymotocross
chevymotocross's Avatar
Re: exhaust pick
I like my Dynomax Super Turbo mufflers. They are quiet at idle with a nice low tone, but when you step on it, they are known. They only seem to drone when the truck is cold and I'm pulling a hill in the morning.
chevymotocross is offline   Reply With Quote
Old 07-25-2008, 07:27 PM   #14
JCampbell
Re: exhaust pick
My Buddy runs stock manifolds with 3" pipe and no cats through Hooker Aerochambers and dumps it out the rear end on his '88, 454-powered dually.
Sounds seriously bad ass. I can't even describe it. It just sounds "right", y'know? Not too loud under normal conditions, but when He's on it, people notice him.
That's what I plan on running.
JCampbell is offline   Reply With Quote
Old 07-25-2008, 07:40 PM   #15
84step
Re: exhaust pick
hmm well from what piecesparts says the flowmasters sound to be the best decision all around. By the way Iam running a stock manifold straight pipes and not exactly sure what the headers are wwould like to know but i just recently bought the truck.
Old 07-25-2008, 07:46 PM   #16
BaddBusa2005
Re: exhaust pick
What magnaflow muffler are you using that rots out? Eveyone I have used was stainless...and were not "low cost"
Old 07-25-2008, 08:31 PM   #17
gearhead1968
Re: exhaust pick
I was thinking the same thing. That is why I like Magnaflow, because the are stainless steel and I think that Flowmasters are overpriced.
Mods:
Old 07-25-2008, 10:23 PM   #18
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: exhaust pick
I'm running longtubes with (real!) Cherry Bombs.. They sound great at idle, but you get into the throttle, they have that "braaap" sound. I really don't like it. I'm probably going to go with a pair of Magnaflows(which I've had before) or SuperTrapps which are tuneable for sound.
Albatrossian is offline   Reply With Quote
Old 07-25-2008, 11:03 PM   #19
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: exhaust pick
I had flowmasters with the small block. The only thing was, with stock manifolds and 2 1/2" pipes straight back past the axle, it sounded like just another Mustang on the road. Don't get me wrong, it sounded great!
But, when I stuck the BBC in, I wanted something different. 3" Dynomax Headers out to turbos and pipes turned out behind the rear wheels yielded a very deep throaty mellow sound so all you really hear is the 552 lift / 286 duration cam in the 454 doing all the talking. But, when you stomp it, it sounds awesome at 5000 rpm.
I guess it boils down to personal preference.
Ken
87Lowrider is offline   Reply With Quote
Thread Tools
Display Modes
