Old 07-26-2008, 04:28 PM   #1
Greubin
Greubin's Avatar
Changed rear diff gear oil and found....
brass flakes, not many but a few, I'm concerned that the bearings are shot, or on their way...everything seems tight, no clunking or excessive play.
Rear axle is a Dana60.
___________
Greubin
'71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI
Greubin is offline   Reply With Quote
Old 07-27-2008, 02:37 AM   #2
JimKshortstep4x4
Re: Changed rear diff gear oil and found....
The only brass in a differential that I can recall is in the spider gear shims.
You may want to check the end play of the spider gears and if excessive, replace the shims.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Thread Tools
Display Modes
