Old 07-29-2008, 01:37 PM   #1
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
front bushings.....
i have a question, im planning on finally fixing the front suspension on my truck but i dont know where to start. to do a total rebuild will set me back like 500 bucks that the economy is not helping me attain. my truck drives nice and straight but there is a small bit of play in the steering wheel and when you hit the brakes it wants to go to either side. i know it needs an alignment but what else can cause the truck to throw itself to one side when you hit the brakes, and its not only one way it can go left or right as soon as you hit the brakes.
staggerd86c-10 is offline   Reply With Quote
Old 07-29-2008, 01:43 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: front bushings.....
Have you aligned it since it was lowered? (based on you avatar..)
That will cause it...
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-29-2008, 01:50 PM   #3
staggerd86c-10
no i havent aligned it yet, i know i need to but it feels like if something is looser(i know thats not a word) then it should be. i dont know if its the steering box or what, there is no play in the steering wheel though.
Old 07-29-2008, 02:15 PM   #4
454HO
Find an alignment shop that will do a free front end inspection. If everthing checks out, get it aligned. If something needs to be replaced, they will tell you what it is.
- Greg
454HO is offline   Reply With Quote
Old 07-29-2008, 02:27 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
I agree, it could be a warn steering gear.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 07-29-2008, 03:33 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
wheel bearings?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 07-29-2008, 06:54 PM   #7
78 Chevyrado
Crawl under the truck and have someone rock the steering wheel back and forth (From 10-11 oclock to 1-2 oclock or so) while you look at the components and see if anything moves where it shouldn't. Otherwise with shafts and balljoints, put a prybar in between say, the lower control arm and the spindle and see if you can move it. Just find out what moves or is loose, that's all you can do. Just don't damage something from prying too hard on it. An alignment shop should do this for you for free, but make sure you see the parts they say are bad, this will help you know what to do better and will make sure they don't try to pull anything on you. Usually lower balljoints are the first thing to go; they have the most pressure on them. Check the steering box shaft for sideways movement while turning the steering wheel back and forth. Tie rod ends can get loose too. Like old rusty said, check bearings too.
I'm not sure how to explain it properly, but there's an adjustment in the steering box that will fix the sloppy steering wheel, if that's the problem. Somebody chime in....
78 Chevyrado is offline   Reply With Quote
Old 07-30-2008, 08:23 AM   #8
staggerd86c-10
thanks for the suggestions, i think i will take it to the alignment shop that i usually go to and have them check it i just wanted to save some time. thanks for all the help guys.
Thread Tools
Display Modes
