Old 08-03-2008, 02:58 PM   #1
70C10Step
70C10Step's Avatar
C-10 Frame Cleaning???
I am cleaning my frame this week so I can paint with POR-15 next weekend. I have wire wheels. Is there any other ways to clean up the frame.... I need manual ways because I do not have access to soda blasting.... I do have a power washer...
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 08-03-2008, 03:41 PM   #2
Shane
Shane's Avatar
Re: C-10 Frame Cleaning???
oven cleaner and the power washer ... cover your eyes and all exposed skin when rinsing the oven cleaner off. buy the cheap stuff from Dollar General / Wal Mart / K-Mart ... the cheaper the better.
Shane is offline   Reply With Quote
Old 08-03-2008, 03:42 PM   #3
big_al_71
big_al_71's Avatar
These are suggestions of what I have done in the past:
* Spray degreaser all over it
* Pressure clean the heck out of it
* Paint thinner all over it
* You could get your self a sandblaster,facemask & sandblast it right on the stands it is on as an alternative. Seen a guy doing it righ on his front yard...
Repeat as neccesary!!! this is what I have done....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-03-2008, 03:46 PM   #4
Ackattack
Ackattack's Avatar
I saw a sandblasting attachment for you power washer that was supposed to work really well.
I didn't see that until after I had sandblasted my frame. It took me waaaayyyy too long to blast mine, and it was very dirty. With the power washer/sandblaster the water keeps all of the sand/dirt out of the air.
I don't remember who sells this setup though.
Ackattack is offline   Reply With Quote
Old 08-03-2008, 03:47 PM   #5
babyJay
Arrived on a Pale Horse
babyJay's Avatar
You might check with your local yellow pages. I can have a frame hot-tanked at a local Galvanizing company for $150, that includes the galvanizing.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 08-03-2008, 06:25 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I recently did my greasy burb frame with oven cleaner and a pressure washer, and I was totally shocked and amazed at the results.
Old 08-03-2008, 06:27 PM   #7
babyJay
babyJay's Avatar
Does this take off the paint too? You've peaked my interest in oven cleaner.
Jason
89 R3500 CC SRW
Old 08-03-2008, 06:57 PM   #8
Shane
Shane's Avatar
oven cleaner will remove paint ...
Old 08-03-2008, 07:09 PM   #9
70C10Step
70C10Step's Avatar
Guys I just used two cans of oven cleaner and the frame is clean. Yes it burns if it gets on your skin but my frame is really clean... it only took about a hour... This stuff rocks. I also had a wire brush out for the heavy areas... I spent $2.00 at the 99 cent store!
All Toys:
Old 08-03-2008, 08:13 PM   #10
Longhorn Man
yep!
I took a putty knife and knocked off the built up grease, then sprayed the stuff on in the sun, let it sit for 45 or so min, and blasted it. I would say 80% of the paint came off, and pretty much all of the grease.
Now... being you are in a very environmently aware area... you'll want to clean up your mess. The grease and oven cleaner on the pavement will not only stain, but it will p!ss off the polution cops.
Cheap stuff;
(ex wife gave it to me, 3/4 full, cost, NOTHING!)
Nastyness;
2 hrs later...Cleaned;
Then I scrubbed it, sanded the rest of the stuff off, scuffed, cleaned and POR'd the front 1/2 of the frame
Old 08-03-2008, 08:18 PM   #11
eric67m
eric67m's Avatar
How does the oven cleaner work on rust? Or what does work to remove rust short of sandblasting?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 08-03-2008, 08:29 PM   #12
babyJay
babyJay's Avatar
Fast Etch will help your rust. http://www.eastwoodco.com/shopping/p...word=fast+etch
Jason
89 R3500 CC SRW
Old 08-03-2008, 10:04 PM   #13
Green Machine
Green Machine's Avatar
A good gas powered pressure washer is very handy and works ok on frames. Next time I am going to rent a commercial style with 3500-4000 psi. Those WILL remove the rust down to the metal.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-06-2008, 11:00 PM   #14
jholley
jholley's Avatar
Hey how heavy was that bare frame? Must have been a pain in the rear getting on those saw horses.
jholley is offline   Reply With Quote
Old 08-07-2008, 10:19 AM   #15
Longhorn Man
i don't know the weight, but it can be placed up there with one person
Old 08-07-2008, 01:26 PM   #16
TotalChevy1
TotalChevy1's Avatar
Someone mentioned the sand blasting attachement for your powerwash, I strongly recommend it. I used simple Green and it worked great. I did take a putty knife and scrap the really thick stuff. After that I took a couple 3m wheels and put the final touches and it came out great.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi)
TotalChevy1 is offline   Reply With Quote
Old 08-07-2008, 04:19 PM   #17
ShowSS12
ShowSS12's Avatar
Yes, but where can we buy the attachment??
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 08-07-2008, 08:37 PM   #18
68gmsee
Active Member
68gmsee's Avatar
I think this is the one that was mentioned on a thread some time back about blasting with a pressure washer.
http://www.northerntool.com/webapp/w...6970_8520_8520
68gmsee is offline   Reply With Quote
Old 08-08-2008, 12:21 AM   #19
mas09ts
mas09ts's Avatar
Does the oven cleaner/ pressure washer work for a rusty frame with no paint?
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 08-08-2008, 01:24 PM   #20
shovelhead
It may be my bad luck, but I had a terrible time with the sandblast attachment to the power washer. The water leaked back into the siphon hose and plugged it up. This creates a real mess. I wish I had gone the oven cleaner route. Good luck to you.
shovelhead
shovelhead is offline   Reply With Quote
Old 08-08-2008, 01:59 PM   #21
68gmsee
Active Member
68gmsee's Avatar
shovelhead
What attachment did you use and what type and size of pressure sprayer (psi)? I was planning on gettin the one from Northern Tools. But, now I'm not sure.
I've got a 3000 psi Karcherl sprayer. I read that the higher the psi the better...
Old 08-08-2008, 04:53 PM   #22
red69ss
Burnouts are therapeutic
red69ss's Avatar
Tried My New Sandblasting Attachment For Pressure Washer Today (pics) ( 1 2)
this is a thread i posted about sand blast attachment, hope to blast my frame with it in a couple weeks,havn't used it much but shovelhead's experience worries me.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 08-08-2008, 09:12 PM   #23
Dusty_case
Dusty_case's Avatar
You know I found when working with oven cleaner the longer you let it sit on the frame the best it works and even better on a hot day
1968 c10 250/3spd
Dusty_case is offline   Reply With Quote
Old 08-08-2008, 11:40 PM   #24
Sequoyah
so easy a caveman can do it...
Sequoyah's Avatar
Scrape all of the gunk off, simple green and pressure wash the rest off, pressure washer with the sandblaster attatchment. I personally don't like the idea of spraying oven cleaner on, rinsing it off with dogs and kids around the house. It's not very good for the grass either.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242380
Sequoyah is offline   Reply With Quote
Old 08-09-2008, 10:48 AM   #25
Shane
Shane's Avatar
But it's ok to use inside an oven which is used to cook the food we eat?
Thread Tools
Display Modes
