Old 08-03-2008, 11:58 PM   #1
Chuck78
Dana 44 rear parts sources? 1962 GMC - posi, axles, bearings, drums, etc?
I've got a 62 GMC 1000 Panel, and am hoping to find a good source and good part #'s for the Dana 44 rear. Most parts databases confuse the chevy rears with the GMC models, so I don't know what to trust.
I think these have the coarse spline, but I'm looking to maybe upgrade to a posi and maybe get rid of the 3.07 for a 3.23-3.42. Not sure. Swapping in a 5 speed tremec. What I really want to do is find parts sources for the axles, brake drums, brake parts, bearings and seals, etc. I'd love to swap out a 30 spline posi if I could find one that would fit and off the shelf axles from somewhere in the right width and diameter. I have heard that the carrier bearings in these GMC rears were different than a standard (newer) Dana 44, and that parts are hard to come by.
I want to swap to 5 lug, but figured I'd probably have to redrill the axle flanges and drums. Want to make sure about parts availability before going that far.
Thanks,
Chuck in Ohio
Chuck78 is offline   Reply With Quote
Old 08-04-2008, 12:04 AM   #2
64c20crewcab
64c20crewcab's Avatar
Re: Dana 44 rear parts sources? 1962 GMC - posi, axles, bearings, drums, etc?
Try Randys Ring and Pinion: www.ringandpinion.com
or
Currie Enterprises: http://www.currieenterprises.com/cestore/dana44.aspx
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 08-04-2008, 05:47 PM   #3
greg64
greg64's Avatar
Hi Chuck,
You and I are on the same path. I want to make similar upgrades to my 64's Dana 44. Here's something from Auburn that looked interesting:
http://auburngear.com/aftermarket/pr...6EPCString3%3d
Notice how it points out that the 70 and earlier had 19 teeth on the spline. Of course, if you swapped the carrier AND axles, you could go to the later 30 spline.
Let us know what you decide to do, because I haven't proceeded yet.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Thread Tools
Display Modes
