08-16-2008, 02:34 PM | #1 |
Active Member
Keyless remote door locks...
Does anyone have them? If you do how do you like them?
I've been kicking around the idea of installing them on one of my trucks. One concern I had was wiring. I didn't want to have wires sticking out of the doors. I thought about some spring contacts that I could mount on the door and frame similar to these fom custom classic: http://www.customclassic.com/catalog...e/wireless.htm |
08-16-2008, 06:22 PM | #2 |
Re: Keyless remote door locks...
I've used something similar before. The key fobs aren't the greatest, but overall I'd do it again.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-17-2008, 12:26 AM | #3 |
i got keyless, but i ran wiring through the door to an alarm, as well as speaker wire and power window wires in the future. love my keyless, and with my alarm i got it to lock doors after engine start and unlocks when i turn the key off. thats great because the lock rods don't make rattling noises when they're locked and i'm driving.
08-17-2008, 03:50 AM | #4 |
how easy is it to put power locks in, iv been thinking about doing but missing the crusial thing called money
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
08-17-2008, 04:21 AM | #5 |
drill holes for actuator and that's about it, run wires, connect rods to rods
08-17-2008, 10:28 AM | #6 | |
Active Member
I like the idea of locking and unlocking with the key. Is that something you rigged yourself or did you also have some instructions for that? Sorry for all the questions... |
08-17-2008, 11:03 AM | #7 |
HI MATT looked at your build page give yourself a pat on the back you did a real nice job on your truck.Were did you get your seat cover from.what happened to your window did someone try brake in ordidyou lock your
08-17-2008, 11:54 AM | #8 |
someone pried/broke my vent window one night but didnt get in. and i got some lock actuators from a local alarm shop, and installed them at the house. they weren't strong enough and i took em back. they called around some random places (i really hate these guys) and they said they were the strongest ones around. i then went to lmc truck and saw they had a keyless kit for 80 dollars, and those actuators worked great. plus with that it's central locking so if you lock or unlock the drivers door the passenger door will do the same. after awhile i got an alarm and wired the door lock actuators to my alarm's brain and it has all sorts of features for it.
Thread Tools | |
Display Modes | |
