Old 08-16-2008, 09:30 PM   #1
1971c20
1971c20's Avatar
i think my starter is done
well i have been dealing with my starter getting to hot. normally i jusy pop the hood and wait 10 min and it sarts right up. But today its acting up but ive waited for several hours now and all it does is click. is my starter done?
1971c20 is offline   Reply With Quote
Old 08-16-2008, 09:48 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: i think my starter is done
Solenoid might be fried. Do you run headers?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-16-2008, 09:49 PM   #3
1971c20
1971c20's Avatar
ya i have headers.
Old 08-16-2008, 09:56 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Classic heat soak symptoms. The starter windings get so hot they won't conduct electricity. Other causes are.
1 Bad connection on battery positive at the solenoid.
2 poor ground from the battery negative.
3 solenoid contacts inside the solenoid are shot.
4. The starter has a dead spot in the armature or the brushes are shot.
If you can get to the starter bendix gear you can rotate the starter a small amount and it may start.
check and clean all positive and negative connections from the battery to the starter and ground.
Most likely you'll need a new starter. To avoid these problems you need either a heavy duty starter, a remote solenoid or a mini starter. You probably have headers-right?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-17-2008, 10:29 AM   #5
cdowns
cdowns's Avatar
chrome mini starters start faster and last longer
Old 08-17-2008, 12:06 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Headers and a lean mixture create a hotter-running engine, making hot restarts easier to experience.
When you replace the starter, be sure to install a heat shield on the solenoid. You can pick one up at AutoShack, etc.
Member Nr. 2770
Old 08-17-2008, 12:17 PM   #7
jhow66
jhow66's Avatar
Put on a remote selenoid-problem solved.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Thread Tools
Display Modes
