Old 08-18-2008, 01:59 PM   #1
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
I think I messed up!!!!!!!!!!!!
I replaced toeboards on both sides. Now when I try to bolt in my innerfender brace, drivers side, my original top bolt holes don't line up (see pics). I am afraid to drill new holes for fear the front sheetmetal won't fit right. Any suggestions?
http://good-times.webshots.com/photo...99708909CBtUxk
http://good-times.webshots.com/photo...99708909DqSwTy
_________________________
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 08-18-2008, 07:26 PM   #2
mylow53
mylow53's Avatar
Re: I think I messed up!!!!!!!!!!!!
hard to see what your doing from the picts. you may want to install the front sheet metal before you bolt this up. can't you drill these after you've answered the alignment question?
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 08-18-2008, 07:31 PM   #3
drummin89
drummin89's Avatar
I say bolt the mount to the inner fender first, then bolt the inner fender to the outer fender and then see where the bolts line up on the cab to the outer fender. And then see If you can mark where the holes need to be. If you'd like I could go get some measurement for you as my truck is apart at the moment and I can easily get to the mounting holes. I have a 52 just for the record.
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Thread Tools
Display Modes
