Old 11-15-2002, 01:56 AM   #1
dvine69
My '69 runs like a$$
My truck runs like a$$ it spudders and sputs I've replaced the carb and intake I also added a used HEI distibutor. what might be wrong?
Rob
Huntsville,TX
Baby Caca Green 69 Chevy
dvine69 is offline   Reply With Quote
Old 11-15-2002, 02:06 AM   #2
bigjimzlll
bigjimzlll's Avatar
did it run ok b4 you changed things?if so, I would double check the plug wires....5+7 are easy to get confused..check the timing, and make sure all vacuum lines go some where or are plugged. eliminate one thing at a time..id start with the ignition and timing.then go to fuel and carb..did you replace the fuel filter? what kind of carb is it?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Thread Tools
Display Modes
