Old 08-20-2008, 11:33 PM   #1
drmiller1
help me help my truck!
Hello to All of You, This is my first post, after reading and learning from all of you. I have a problem with my 69 C10-350. I was having problems with my taillights, very dim (rust and rust and more rust)so after reading here I ran new ground wires to the frame from the battery and to the motor from the battery. I also ran another ground from the battery to the firewall at one of the two studs that hold the parking brake. After checking each lamp and running new grounds to both , this fixed my taillight problems(sunglasses now required!) but when I went to start the truck-nothing, no clicks, clacks, nothing.
I noticed when turning the ignition key , that the brake light indicator on the dash lights up. Any ideas from you guys would be greatly appreciated!
Nothing better than an old truck...
76 C-10 Silverado
92 Silverado Z71
drmiller1 is offline   Reply With Quote
Old 08-21-2008, 07:42 AM   #2
cdowns
cdowns's Avatar
Re: help me help my truck!
welcome to the board from daytona beach
if the truck is an automatictranny the first place i'd check is the neutral safty switch its located near the bottom of the steering column down near the floor(also make sure its in park or neutral) theres a heavy gauge purple wire that come from the ign switch to the safty sw then goes thru firewall to the starter
Old 08-21-2008, 08:03 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Try slightly moving your shift lever while turning the ignition key.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 08-21-2008, 08:50 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Welcome....
After checking the trans switch, also check the junction connectors and fuses, fusible links, etc. A voltage meter is needed at this point to see if you're getting voltages to the different components like the solenoid.
Here's an easy to read diagram provided by one of our members. Let me know if you need the inside the cab diagrams.
68gmsee is offline   Reply With Quote
Old 08-21-2008, 11:06 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the fuseable link was bad, the truck would get no p[ower at all.
After checking the neutral safety switch, you need to have someone try cranking it over while you check the S terminal on the starter with a test light.
Your brake light on the dash is supposed to light up when you turn the key to the crank position.
Old 08-21-2008, 06:03 PM   #6
drmiller1
Well done! Thanks to all for the help. When I looked at the neutral safety switch
I discovered the purple wire was not plugged to it. After hooking the wire back to the switch, it still was dead. A jumper wire to bypass the switch got it running again. I'll replace the switch and move on to the other problems.Thanks again.
76 C-10 Silverado
92 Silverado Z71
Old 08-21-2008, 07:10 PM   #7
Longhorn Man
sweet!
Thread Tools
Display Modes
