Old 08-28-2008, 11:14 PM   #1
longorange68
GM Rallye Wheel Question and pic request
Hey,
Looking to spruce up my wheels, have been running the 4WD rallyes for quite a bit. Since I used to have no money and kind of relied on used tires for my rig, the beauty trim rings have done a number on the painted surface of the wheels. See the first link for a pic of this type of wheel.
http://www.stocktonwheel.com/light_truck_wheels.htm
The wheels I have are 6 lugs and are the 4th picture down.
I am looking to take these wheels down to bare metal and either powdercoating or painting them a darker metallic shade of gunmetal grey. Either I am really stupid or just a glutton for punishment, but I put in a drop kit and kicked down the extra $100 for Early Classic to run the 6 lug front discs. Seems like the aftermarket is pretty much tailored for the 5 lug wheels and I am up a creek. I really like the fat whitewall look, but am not really into the full blown rat rod type flat black paintjob. What I want to do is keep things simple and run some sort of "spider cap" over the 6 lugnuts. In my opinion less is more, especially with wheels...
Here is an example of a spider cap.
http://www.hubcapmike.com/spider-c8056.html
Does anyone know of someone who makes these for us 6 lug folks, or am I still up that creek?
I was hoping to not have to do the poor man's spider caps with the bullet and the specially tipped lugs, but is that the only option I have open to me?
PS--Anyone have any photos of a truck rallye with an other than stock color? Would like to see what it would look like in a color other than light silver.
Thanks.
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears
Good judgment comes from experience, and experience, well......that comes from bad judgment.
1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then.
longorange68 is offline   Reply With Quote
Old 08-28-2008, 11:40 PM   #2
corn
Re: GM Rallye Wheel Question and pic request
When I had my 6 bolt rallies on my truck, I looked & looked for aftermarket caps & found only stock replacments. You will probably have to make some. I ended up running rings & no caps until I put my slots on...Good luck with the search & if you find something, let me know...
corn is offline   Reply With Quote
Old 08-29-2008, 12:42 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
one or two steps darker than stock;
if you like that... then check out this RIM JOB thread. The thread has wheel progress on all 3 pages.
Old 08-29-2008, 05:52 AM   #4
Not the type of vehicle or style you are after,but when my Blazer was new I had another set of rallyes powdercoated gloss black and stripped the silver paint off the flange of the center cap.There`s great chrome under there.I like the idea of gunmetal grey on these wheels.The thing with rallyes is they are GM wheels designed to accept GM centers,no aftermarket picked up on making an alternative.
Old 08-29-2008, 07:56 AM   #5
eseaton
eseaton's Avatar
you can run the newer 6 lug center caps like longhorn man is showing on the 5 lugs.
eseaton is offline   Reply With Quote
Old 08-29-2008, 08:00 AM   #6
eseaton
eseaton's Avatar
heres what mine were when I got the truck. I am going to paint them to match the truck again and use the rings and centers again.
Old 08-29-2008, 08:20 AM   #7
68Stepbed
68Stepbed's Avatar
I too really liked this look when I had rallies on my 68. There's 2 ways to install these. Go to a local tire dealer somewhere in your area. They should have these hubcaps in stock or could possibly tell you where to find them. You can also find them at swap meets. A tire retailer should have the original style lugnuts that the plastic lug cover thread onto and hold the cap on.
Another way is what I have done. These caps have tabs on the backside of them between the lug holes. They line up perfect with the center cap mounting holes in the wheels. The tabs have small caps in the ends of them. Take the tabs out of them. Go to a hardware store and get some 1/4"x20x1"
self threading screws. Line up the tabs with the mounting holes and put the screws into the tabs from the back side. Try not to overtighten them, the plastic can strip out pretty easy. You can still tighten them enough to hold them on. Then just use regular chrome lug nuts to hold the wheel on.
This is the only pic I have right now. I have some better, more detailed pictures that I will post later if needed. I know these are 5-lug, but the process is the same. I have a piture of a 6-lug whell done this way, but will have to find it.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-29-2008, 10:31 AM   #8
Longhorn Man
my rim job thread addresses mounting the later caps... if going the chrom lug nuts, i recomend the real long closed ones
Old 08-29-2008, 05:43 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would like to go with a "Dog Dish" center cap on my Rallies.It seems like it would be worth someones time to build a spring loaded ring that would bolt to the original holes for the centers.It could then hold any type small cap you chose.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-29-2008, 06:49 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
ttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-29-2008, 08:29 PM   #11
longorange68
Longhorn Man, that is some nice work in your thread, those wheels look clean!!! What I want to do is make my wheels look a little different without making them standout as too dark of a color.
This is is the look I am going for.
http://www.hubcapmike.com/spider-hubcaps-photos.html
But since no one does this for us 6 lug guys, could I go with a something like this with some dome top long lugnuts to at least get close to the look of a spider cap? Anyone ever use a push through type with any luck?
Scroll down and look under misc.
http://www.petepaulsen.com/Accessories/Caps&Trims.htm
Old 08-30-2008, 12:08 PM   #12
longorange68
ttt
Thread Tools
Display Modes
