Moderator
![]() Join Date: May 2007
Trans linkage/Back up switch problem
I just installed an overdrive 4sp indicator, and Lokar style linkage for my 700R4. I got the shift indicator to line up pretty well, and can shift all the way down into 1st gear. The problem I am having now is that my back up lights do not come on until I am in neutral, NOT reverse. Do I need to adjust the linkage another way, or adjust the neutral safety (back up) switch? Thanks!
still buypickupparts
Re: Trans linkage/Back up switch problem
I adjusted the backup switch, it took a few times but it will come in, may I ask where did you get the shift indicator for the columb, cuz I need on
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
Moderator
Thanks...I will give it a try. I got the shift indicator and the linkage from truckandcarshop.com. The indicator is made by Counterpart and the linkage is made by Kugel Komponents.
Thread Tools | |
Display Modes | |
