11-16-2002, 02:33 PM | #1 |
help with glove box install
I bought a new glove box for my 72 Jimmy. The truck has a/c. Does any one know how to get the glove box in? I can't get it to fit. It is like they are supposed to go in from the rear. Any tips will be appreciated.
Thanks, LT |
11-16-2002, 02:48 PM | #2 | |
Bloo
are you sure they sent you the one for a A/C truck and not a non-a/c?
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
11-16-2002, 02:52 PM | #3 |
Where's my beer?
Did you get one for a a/c truck? I believe the ones for a non a/c truck are different, can some assure this?
11-16-2002, 03:39 PM | #4 |
The AC boxes are shaped different at the rear but the front is still the same. I think originaly they did install these first, then the heater box. But you can slide it through the glove box opening one side at a time. Notice there are reliefs designed into the corners. Once its in... it ain't comin' out lol. You'll likely rip it to streads trying to take it back out.
11-16-2002, 04:17 PM | #5 |
Old member
A/C or non A/C Glove box
The A/C glove box if looking at it from the seat it will have a indention on the left side of it for the air connections. Other than that they are the same.
When you install it it will fold up a little around the conners, but it should be alright after installed. I always install mine starting with the left side first, it just seems to go in easier. Hope this helps.
Thread Tools | |
Display Modes | |
