Old 09-07-2008, 05:14 PM   #1
KMACD71
KMACD71's Avatar
Advice on dash pad
I just installed this dash pad a few months ago.It's from LMC .There is a bump where the built in hardware sits in the pad to bolt it to the dash.Anyone have this issue before and know how to fix it?It's only on the one side of the dash pad.
KMACD71 is offline   Reply With Quote
Old 09-07-2008, 07:36 PM   #2
jef5150
Inline 69
jef5150's Avatar
Re: Advice on dash pad
make sure the pin is pushed ALL the way into the dash,it happened to me also.Possibly not in the hole at all.
jeff
jef5150 is offline   Reply With Quote
Old 09-07-2008, 08:20 PM   #3
Andy4639
Old member
Andy4639's Avatar
Looks like one of the studs is not in place.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-08-2008, 12:49 AM   #4
KMACD71
KMACD71's Avatar
Thanks for the advise.I'll take a closer look tomorrow to see if I have it attached properly.
Old 09-08-2008, 08:25 AM   #5
Andy4639
Old member
Andy4639's Avatar
Take a flashlight and look inside the glove box over top to see if all the holes are filled.
Old 09-08-2008, 01:04 PM   #6
KMACD71
KMACD71's Avatar
The studs is there and I have the nut tight but it just doesn't pull that part of the dash pad down.I think the stud isn't attached properly to the dashpad.It's not pulling the top part of the pad down above the stud.
Old 09-08-2008, 01:26 PM   #7
jef5150
Inline 69
jef5150's Avatar
i still think your pad is not seated all the way down,I'd loosen it up and try again.Mine did the same thing!
they are threaded and your probably caught on a thread of the bolt...it will tighten up but its not allowing the pad to sit flush.
jeff
Old 09-08-2008, 02:10 PM   #8
jef5150
Inline 69
jef5150's Avatar
My dash isnt screwed in yet....im bored..
so i went and pulled up 1 stud halfway, and it look just like yours does.
(plastic bag stops flash glare)
jeff
Old 09-08-2008, 02:42 PM   #9
Musclerodz
it is the aftermarket urethane dash dilema. Camaros, Chevelles, etc, are all made by the same company and there are some issues. The only way to make it go away is to glue that spot down. Unfortunately no ta lot of choices in companies for aftermarket dash pads.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 09-08-2008, 04:55 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
I had a similar problem on my 72. I took all the screws back out then installed only the tops and tighten them and the istalled the lowers.
dwcsr is offline   Reply With Quote
Old 09-08-2008, 06:25 PM   #11
KMACD71
KMACD71's Avatar
Tightened it too much and the bolt came off the metal strip that is seated in the dash.oops. I took the pad out and the bolt was at the edge of that strip probably not seated properly so the bolt and about an inch of that strip are now out of the way so I'll see later how it sits with one missing bolt.
Thread Tools
Display Modes
