Old 11-18-2002, 02:30 PM   #1
racedvl
racedvl's Avatar
Unhappy Heater core.........
Well, I went to check my oil this morning and noticed anti-freeze leaking down my firewall near the heater core hoses. I will of course check the hoses for tightness, but if I need a heater core, what is involved in replacing it? It does not have a/c. Thanks. 1986 GMC.
racedvl is offline   Reply With Quote
Old 11-18-2002, 03:23 PM   #2
Zilverado
Zilverado's Avatar
Replacing the heater core is no big deal, just takes a couple of hours. Did mine last fall (on an A/C truck). Just a few comments.
  • The heater core is located inside the distribution box which is inside the cab, behind the glove box.
  • Remove the glove box for access.
  • All but one of the fasteners for the box are removed from the engine side of the firewall. There is one (I think) which comes off from inside the cab.
  • Once the distribution box is loose, you just have to finesse the thing out.
  • Be careful when disconnecting the heater adjusting cables and any vacuum hoses. take note of where they come from so you can reinstall them correctly. I had one vacuum hose which came from the top of the box. Kinda tricky to get at, just take your time.
  • Once the box is oout, the core is a piece of cake.
  • Reinstallation is the reverse (of course).
Just be sure you pressure test your new core - even if it's just with a garden hose. The first new core I tried, I just held the hose to one inlet on the core and covered the other with my hand. This was enough to identify a bad solder joint.
Anyway, that's about it. I'm sure you'll get more input and advice. So have fun with it and chalk it up to experience.
Zilverado is offline   Reply With Quote
Old 11-18-2002, 10:45 PM   #3
rolson1039
heater core
ok call me over cautious, but when i took apart the vacuum lines and cables and all i went and labelled it all. it made it easier when i put it all back together.
Also when you put the bolts back into the heaterbox, you have to not overtighten them cause my friend did his in a rice burner and he overtightened and cracked the heater box
Hope all this helps
rolson1039 is offline   Reply With Quote
Old 11-19-2002, 12:14 PM   #4
PHOENIX
All i need to say is changing a heater core on one of these trucks is ALOT easier thena car. I have a non-ac truck and can help you out if you run into any problems.
My truck had 3 nuts on the firewall that I had to take off. They are the 3 that are on threaded bolts. I believe the only nuts near that area. Becarefuly though my nuts were stuck on the bolts and I ended up bending a bolt or two. Still went back together though. In other words what Im saying is dont remove any bolts from the engine bay on the non-ac models, just remove those three nuts.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Thread Tools
Display Modes
