Old 11-18-2002, 05:19 PM   #1
jmac
Lightbulb blazer 4x4 to 2x4
hi everyone. so what does it take to go from a 4x4 blazer to a 2x4 blazer? is it a matter of changing front end parts from an 2x4 donor to the 4x4? How much problem can this be?
jmac is offline   Reply With Quote
Old 11-18-2002, 05:23 PM   #2
Alexis
Member since 2000
Alexis's Avatar
that pretty much it..........i think there are 2 members trying to do this. Was it the 2wd blazer thread that got you thinking? i dont think it woul dbe tht hard to switch a 4x4 into a 2wd.
Alexis is offline   Reply With Quote
Old 11-18-2002, 05:27 PM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Well, I am researching this now and if you just want to change over the front end then you are correct. Get a donor and they will swap. The rearend is where I am thinking will be more work. I would want to get rid of the leaf springs there and go with a coil set up. That is a lot more work though. Crossmembers will have to be changed out etc.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-18-2002, 05:30 PM   #4
Alexis
Member since 2000
Alexis's Avatar
i thought it could not add a original coil rear-end due to the way the frame is straiten oout in the rear.........coil over 4 link setup?
Old 11-18-2002, 06:27 PM   #5
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Aside from suspension components the front bumper mounts are different between 2 & 4WD. I found this out when trying to order brackets for my 4WD Blazer. If you go ahead with your project and don't need the front outer bumper brackets I would be interested in them.
Good luck and thanks!
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
Thread Tools
Display Modes
