Old 09-18-2008, 09:04 PM   #1
Smithereen
Transfer Case Number...c-98404 A10?
Trying to figure out what t-case i got in this truck i just picked up it's a '67 3/4 ton with a 350.
Smithereen is offline   Reply With Quote
Old 09-18-2008, 09:23 PM   #2
odog
odog's Avatar
Re: Transfer Case Number...c-98404 A10?
Maybe a rockwell t221. Not sure about the serial #. My 67 3/4 ton came with the t221, but had a 327 instead of the 350. what tranny does it have?
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 09-18-2008, 09:28 PM   #3
Smithereen
I'm not sure what the tranny numbers are but it is a 4 speed standard.
Old 09-18-2008, 09:30 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
What does the shifter nob say?? If it goes L 1 2 3 R then I believe it's a SM420 but if it says 1 2 3 4 R then it's a SM465 which isn't the original tranny. The motor may have been the only thing swapped so you might still have the original tranny and xfer case which should be the 420/T221 combo.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-18-2008, 09:50 PM   #5
odog
odog's Avatar
what is the shift pattern on the t case. My t221 is 2wd all the way forward, then 4hi, N then 4 low. Np 205 is 4low all the way forward, then N, then 2wd then 4hi pulled back towards seat. Don't know if this helps. I will try to find a spot to look up the tcase number.
1969 4x4
Old 09-18-2008, 10:55 PM   #6
Smithereen
thanks guys, i found a link that shows some detailed pics, i've got a np205, i know the truck has been played with a bit so it wouldn't surprise me if this is not stock.
Thread Tools
Display Modes
