09-22-2008, 05:11 PM | #1 |
Door locks
Just bought a truck and wanted to know if there was anything I can do to fix my door locks. The truck is a 69C10. The doors lock with the key, but when you press button, you can open doors. This should not happen. Is there something worn in the handles.
Thanks |
09-22-2008, 05:34 PM | #2 |
Re: Door locks
are you trying to push the button down then closing the door expecting it to stay locked? if so they dont work like that you need to use the key the oldschool way to lock doors
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 09-22-2008 at 06:01 PM. |
09-22-2008, 06:04 PM | #3 |
Re: Door locks
I don't get it. So you are stating I can never permanently lock my truck. Just for clarification, I lock with key, push the button and the once what I thought was locked door is now open. How do you lock them then and what is the purpose in having them work this way. How do I secure my truck from thieves.
09-22-2008, 06:10 PM | #4 |
Re: Door locks
sometimes when i lock mine and the inside handle is not down all the way it does not lock properly and will open as you describe.
hope this helps. |
09-22-2008, 06:21 PM | #5 |
Always on the hunt...
Re: Door locks
Your door latch/lock assemblies probably just need lubed up, they may not be fully engaging into the locked postion with the key, allowing them to pop back into the unlocked postion as soon as the button is pushed in on exterior handle. With the door glass rolled down, push the interior lock knob all the way down and then try to open by the exterior door handle, if the door does stay in the locked position I would then look for stuck or worn parts between your keyed door lock and the door latch/lock assembly.
09-22-2008, 06:36 PM | #6 |
Re: Door locks
The levers on the back side of the lock are more than likely gone. If the key rotates 90 degrees and does not lock the door then this lever is either gone or bent where it doesn't contact the door mechanism. You'll have to pull the door panel to see this.
69 Chevy 4x4 383 Power |
09-22-2008, 07:05 PM | #7 | |
Re: Door locks
Ok, do they sell replacement parts to fix this. Something is obviously worn. They lock fine with key so oiling is not issue. They just open without the key. I am not opposed to getting new handles. Will this fix. Thanks |
09-22-2008, 07:22 PM | #8 |
Re: Door locks
They sell all the parts for these trucks. Go to http://www.lmctruck.com/icatalog/cb/t.aspx and look at the pictures of the locks then look at yours and see whats missing.
69 Chevy 4x4 383 Power Last edited by haysonj; 09-22-2008 at 07:23 PM. |
09-22-2008, 08:09 PM | #9 |
Inline 69
Re: Door locks
the ""key lock" and "inside cab lock" are connected to the mechanism in pic 1 at opposite ends.
It pivots in the center and when you lock the door using either lock.That "point" slides up and prevents the outside door button from opening the door.2nd pic is what does what. This is from my passenger door,so everything on drivers side is mirror image. sorrysoblurry jeff |
09-22-2008, 08:24 PM | #10 | |
Re: Door locks
09-22-2008, 09:08 PM | #11 |
Inline 69
Re: Door locks
you,ll need a 7/16 wrench/socket for the handle,Theres 2 bolts.
Your button assembly "should" go back together. it just a thin plate of metal with a couple tabs you bend to hold the spring in place. You want another picture? jeff |
Thread Tools | |
Display Modes | |
