Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-23-2008, 12:53 AM   #1
ton*loc
ton*loc's Avatar
big block 292 heads ?
i picked up a pair for super cheap yesterday. they are off a 72 corvette 454. i was just wondering if there a good head to work with or i should try to get something else ? trying to make some good power with this bigblock build any thoughts ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 09-28-2008, 03:17 PM   #2
ripdog28
ripdog28's Avatar
Re: big block 292 heads ?
They can make decent power with some work. I went with Dart iron eagle 308cc because with the price of old iron, Port job, Valves and springs it would be about the same as some after market iron. If you or a friend can port then you saved a lot.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Thread Tools
Display Modes
