09-24-2008, 10:55 PM | #1 |
Lower control arm ball joint question
Anyone else have a REALLY hard time pressing these ball joints out? been throwin tool's for half the day trying to get it out. Oxy acetylene tanks were empty
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
09-24-2008, 11:17 PM | #2 |
Re: Lower control arm ball joint question
I ended up using a small grinder to cut the rivets on mine
09-24-2008, 11:22 PM | #3 |
the lower's are riveted?
09-24-2008, 11:23 PM | #4 |
My 62 was
09-25-2008, 01:47 PM | #5 |
Same on my 64 C10
09-26-2008, 03:00 PM | #6 |
Registerd User
My 65 is a press in. It was stubbern at first so I got a bigger hammer. From what I've seen c10 and c20 are both press in lowers and bolt in uppers.
09-26-2008, 09:27 PM | #8 |
thanks!
09-27-2008, 12:53 AM | #9 |
KOFFIN DRAGGER
I hit both of mine less than 5 times each with a 3lb sledge hammer and they fell out. When in doubt, get a bigger hammer. Your not going to hurt the control arm, whack the s**t out of it.
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
09-27-2008, 02:10 AM | #10 |
65 - Chevy C10
true! the only thing is that our were probably never detached so its gonna take more than 5 wacks!
09-27-2008, 10:02 AM | #11 |
KOFFIN DRAGGER
I know the upper had been changed, not sure about the lower. I supported the control arm with 2 floor jacks, 1 inside the arm towards center and 1 outside at the edge. Now when I say "5 whacks" we are talkin full swing man whacks hitting the stud part as hard as possable. I am 265lbs, I can whack something pretty hard. I also had the front clip off the truck, so I kinda cheated.
09-27-2008, 02:32 PM | #12 |
Haha, well, stupid me, dident read the instruction's on the ball joint press tool (Im a guy, i geuss its in my blood) and i was using the wrong fitting and doing it from the wrong side! both lower's are out and waiting for the new front end rebuild to come in the mail! thanks for the info everyone
09-27-2008, 09:10 PM | #13 |
Resistance is Futile
I used one of the large C-clamp deals to remove my ball joints but could not get them back in using the same tool. Had to use a press.... mite have been easier if the control arms were mounted; in case you have trouble.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
09-27-2008, 09:35 PM | #14 |
1960 GMC Burb
On my 60 I drilled the original rivet out, ground it flat, used large hammer to punch them out. Then got a larger sledge hammer and got the job done.
Good luck, it sucked for me.
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
Thread Tools | |
Display Modes | |
