Old 09-30-2008, 06:16 AM   #1
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
U-bolts
I am looking for rear U-bolts for my 72 Blazer and am having a hard time locating them. They are the squared off style that go over the spring pack...is this stock? I need them to be long enough so I can put in a zero rate block also. Any ideas? Thanks.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 09-30-2008, 08:04 AM   #2
AJs72K5
AJs72K5's Avatar
Re: U-bolts
Any reason you wouldn't want to switch to the flipped style? This puts the nuts and the threads on top of the spring. Helps a bit with ground clearance. There's a bunch of vendors that can get you ones in that style.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 09-30-2008, 09:02 PM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: U-bolts
I have this same issue with my 71 Blazer 4x4. The 73-up trucks have 2.5" wide springs compared to our 2" wide springs so I don't know if the upper plates on the 73-up trucks will work with our trucks?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 09-30-2008, 09:47 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: U-bolts
Custom, I went to the spring shop here in town and told them what i needed and about 20 minutes later they had them for me, it was 37 bucks for all of them.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-30-2008, 09:54 PM   #5
BLUE THUNDER
BLUE THUNDER's Avatar
Re: U-bolts
What spring shop? Where?
BLUE THUNDER is offline   Reply With Quote
Old 09-30-2008, 10:27 PM   #6
Jtrux
Jtrux's Avatar
Re: U-bolts
Downtown, ace spring.
Old 10-01-2008, 06:23 AM   #7
Chevyman63
Chevyman63's Avatar
Re: U-bolts
I guess just a little less work and a little less $$. I did see that the other style is readily available, but didn't see that much of a benefit for the effort of grinding off the old mounts, but since it is so hard to find the stock bolts in a longer length, I'll probably opt for the flip style.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 10-01-2008, 07:48 AM   #8
bigdon-70blazer
Re: U-bolts
Did you check out LMC? I got all of the correct U-bolts and the squared off ones correct from them for my 1970 blazer. Just a suggestion...
bigdon-70blazer is offline   Reply With Quote
Old 10-01-2008, 08:11 AM   #9
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Re: U-bolts
If You Have a Rural Fleet Store Neary by, Check them out. I Seen Several size's of that U bolt in the one near me...............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 10-01-2008, 12:57 PM   #10
badpeanut
badpeanut's Avatar
Re: U-bolts
I bought squared off style U-bolts for my '72 leaf spring two-wheel drive from Early Classic, but the four-wheel drive U-bolts are different.
'70 GMC LWB trailer
Old 10-01-2008, 02:46 PM   #11
71jimmy
71jimmy's Avatar
Re: U-bolts
WHOA dude, there is no grinding off the old mounts required. It's strictly "plug and play" if you will. Take the old off, put the new on.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 10-01-2008, 04:13 PM   #12
Jtrux
Jtrux's Avatar
Re: U-bolts
Yep. I think the kits run about 70, includes plates and bolts.
Old 10-01-2008, 06:05 PM   #13
Chevyman63
Chevyman63's Avatar
Re: U-bolts
I just assumed (I know never assume) that the bracket on the bottom of the axle tube was welded on. That's good news!
I did look and found several vendors who carry the stock u-bolts, but I didn't know if they would be long enough with the zero rate blocks.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Thread Tools
Display Modes
