Old 11-20-2002, 11:53 AM   #1
Canada20
4-speed manual column shift; any such thing?
Hey all. Just curious if they ever offered a column shift for the manual 4-speeds? Probably pretty clunky to use if they did.
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 11-20-2002, 12:13 PM   #2
Woody
True! No such thing as a stupid question. Now on to the question. As far as I know all 4 speeds were floor shifters and the columns didn't have any thing on them. 3 speeds trucks were all Column shift.
Woody is offline   Reply With Quote
Old 11-21-2002, 12:40 AM   #3
Bowed
Drove a german car one time with a 4 speed column shift , cant remember the make but it was sold here in the early 60's .
Bowed is offline   Reply With Quote
Old 11-21-2002, 12:43 AM   #4
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
I rode in a 5 on-the-tree Nissan Taxicab in HongKong last week. RH drive also. Friken wierd shifter, left side of wheel.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 11-21-2002, 01:00 AM   #5
mikep
Used to have a truck
mikep's Avatar
Ever driven a Citroen CV2 with the 3 speed dash shifter? That takes a little getting used to.
No truck :-(
mikep is offline   Reply With Quote
Old 11-21-2002, 01:10 AM   #6
too many
too many's Avatar
Question WHAT ABOUT........?
Ive never seen one , but did some of "our" trucks come with 3 speed overdrive? Was that actually a "4th" gear , or just a "higher" geared 3rd? How did they shift?
"My wife says I cant have them all - I tell her I can try!"
too many is offline   Reply With Quote
Old 11-21-2002, 01:22 AM   #7
junkyardjohn
junkyardjohn's Avatar
Lightbulb
I DROVE A PEOGOT, IN THE EARLY 70s THAT HAD A 4 SPEED MANUAL COLLUM SHIFT. I RODE TO A BAR ONE SAT. NIGHT WITH A BUDDY, HE LEFT WITH SOME YOUNG LADY, & GAVE ME HIS KEYS TO DRIVE HIS CAR HOME. SEEMED PRETTY WEIRD AT 2:30 AM
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-21-2002, 05:29 AM   #8
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Had a Borgward in the 60's. In college, 5 of us drove from Boulder, Colorado to L.A. for spring break. Had to back over Loveland pass, not enough guts in 1st. Had a column 4 speed.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 11-21-2002, 09:13 AM   #9
Blazer1970
Blazer1970's Avatar
There was an add-on overdrive available for the column shift 3 speeds in trucks and cars of this era. The overdrive gear was shifted by a solenoid.
Blazer1970 is offline   Reply With Quote
Old 11-21-2002, 11:26 AM   #10
Canada20
I was talking to a buddy here who's played around various trucks off and on. He seems to think that the column shift only works on transmissions where the shift linkages are on the outside of the case and since the Sm420 and 465 are internally shifted, there's no way to hook a column shift up to it. Sounds reasonable to me...
I wish we had some more of the variety of European cars that have been made over the last 50 years; some pretty wacky ideas out there, even compared to AMC
I was checking out my owners manual last night and there was indeed a 3-speed with overdrive. Sounded to me that OD was a kind of mini-automatic that you could only use from 3rd gear? or am I way off on that?
Greg
Old 11-21-2002, 12:25 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Haven't seen a comment yet, but I believe that Ford had a 4-speed column shift on the early-bodied Econolines. If it wasn't Ford, then it was Dodge. Surely, GM didn't do that with the early G-series vans, did they? Could be, tho.
Reason Ford comes to mind is the Dagenham 4-speeds that were available in the early Falcon and Comet bodies, AND recognizing that those transmissions were imported from Europe.
Anyone else know?
Question: WHY would you want a 4-speed on the column, short of a "cool" factor? That would require waaaaaaaaaaaaay too much in the way of linkage.
Overdrives? Affixed to the tailshaft of the 3-speed transmission housings and usually operated by electric solenoids.
Citroens and Peugeots.....ain't it enough just to spell the names, much less operate those dash-mounted shifters? They were weird, for sure...even though Peugeot and Mercedes-Benz had theirs on the column.
Member Nr. 2770
Old 11-21-2002, 12:49 PM   #12
Canada20
Interested mostly for interest's sake and a little of the "cool" factor. Come to think of it, there might be a bit of theft-protection in it too; if they can't figure out how to shift it, they won't get very far.
Are the overdrives any good? At a guess I'd say probably not, otherwise there'd be more talk of people finding ways of installing them on their 4-speeds.
Greg
Old 11-04-2012, 04:39 PM   #13
71gmcburb
71gmcburb's Avatar
Re: 4-speed manual column shift; any such thing?
yes Ford did have a 4 spd column shift trans till 1965 and it appers the GM did too
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 11-04-2012, 05:35 PM   #14
LockDoc
The Older Generation
LockDoc's Avatar
I put a Muncie M-21 in my first '67 and used the column shifter. I installed a choke cable in the dash for reverse. You just had to remember to put the shifter in neutral before you pulled the choke knob out. My boy had a little trouble the first couple of times he drove it but he caught on pretty quick when it killed the engine when he tried to take off in it..... I still have the choke cable and bracket I made around here somewhere and that was in the late '80's.
LockDoc
Leon
Old 12-01-2017, 10:02 PM   #15
JLC64
JLC64's Avatar
Chevy made a 4spd manual column shift in chevy/gmc vans from 1964-1970. I am in the process of swapping my 67 K10 over to one.
Jim
JLC64 is offline   Reply With Quote
Old 12-01-2017, 11:43 PM   #16
Hutch
Hutch's Avatar
I drove a German made car back in the 70’s with a 4 speed column shift
It was a 1960’s Ford Taunus
It was a trick to get the hang of and then hard to readjust to a 3 speed column shift
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 12-01-2017, 11:55 PM   #17
Steeveedee
Who Changed This?
Steeveedee's Avatar
THREAD FROM THE DEAD! Corvairs also had a 4 speed that shifted on the column.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-02-2017, 12:34 PM   #18
RichardJ
Corvair never had a column shifter, car, van or pickup. 3sp and 4sp had floor mounted shifter. 2sp Powerglide had dash mounted lever/cable shifter.
As JLC64 said, the G Series Van had a 4sp column shifter with T10 4 sp. I think it was only in 2nd Gen, G Series '67 - '70. In '71 they moved the engine forward under the short hood for the 3rd Gen.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 12-02-2017, 01:26 PM   #19
In The Ten Ring
Saw a video on youtube about a 4 speed column shifting Ford.
Personally I love my 3 speed on the column for a variety of reasons....I do wish my truck had more top end without sacrificing pulling power.....lots of hills around where I live. *I wouldn't want to have to pull a 2nd lever for reverse though like in the link below.
https://www.youtube.com/watch?v=BjkRB1Ibjj0
I went to India in 1997 and the Ambassador car was everywhere. A friend there owned one and let me drive it on a backstreet. Right-hand drive takes some getting used to but wasn't that bad. It was a 4 speed in the floor (you shifted with your left hand but the 3 pedals were the same). When I got back to USA I had a strong urge to drive on the wrong side of the road.
https://qph.ec.quoracdn.net/main-qim...61c441347e7032
In The Ten Ring is offline   Reply With Quote
Old 12-02-2017, 01:42 PM   #20
Greg58
Greg58's Avatar
My Buddy in High School had a 1960 Mercedes 190D, it was really slow. 4cyl Diesel, 4 speed on the column.
The only thing slower at the time was my Dad's 1962 Scout, 4 cyl. that was half a V-8.
Greg
________________
1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd.
2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold}
1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400
2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax.
Greg58 is offline   Reply With Quote
Old 12-02-2017, 08:21 PM   #21
67swb72klb
67swb72klb's Avatar
There was a thread on here where a member was doing a column shift 4 speed
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 12-03-2017, 09:44 AM   #22
kiwikid
had an Austin A40 4 on the tree would be cool today
kiwikid is offline   Reply With Quote
Old 12-03-2017, 11:49 AM   #23
52napco
My dad had a 1967 Impala and in the owners manual there was a 4 speed column shift illustration and description of operation.so yes but it would have to be a Saginaw or Muncie
Application
52napco is offline   Reply With Quote
Old 12-03-2017, 12:42 PM   #24
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, my bad. Rusty memory on that one.
~Steven
Simi Valley, CA
Old 12-03-2017, 10:55 PM   #25
outfield
My grandparents 1965 Mercedes 220S is a 4 speed on the column. Interesting to drive.
outfield is offline   Reply With Quote
Thread Tools
Display Modes
