10-04-2008, 10:29 PM | #1 |
Future TOTM Winner
Electric fan
How much air flow (CFM) would I need if I removed my stock fan and used an electric setup. Condidering I have a mild build 350 with A/C in South Texas heat.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
10-05-2008, 06:14 AM | #2 |
Re: Electric fan
All you can get.
Pulling air through is better than trying to push it through. (don't know how you intend to mount though) |
10-05-2008, 07:33 AM | #3 |
sharp as a marble
Re: Electric fan
I had an aluminium be cool radiator, and 2, 11" Spal fans on my 502 Chevelle, and it would keep up with Florida summers. 3/4 up the gauge. If you go to www.spal-usa it will show CFM ratings. I think this is a case of more is better. Currently own a 69 SWB, and will be installing A/C soon. I am thinking about the 12" dual spal's, and their fan controller. I have a 4 row copper/brass radiator in my truck now, and with no A/C it does just fine
10-05-2008, 07:57 AM | #4 |
Re: Electric fan
...a shroud is key also.
10-05-2008, 08:30 AM | #5 |
Re: Electric fan
There was an electric fan install in the truck section a while back. The setup was from a late model Jeep. I am thinking about giving it a try.http://67-72chevytrucks.com/vboard/s...d.php?t=254617 I finally got the link to work.
10-05-2008, 08:35 AM | #6 |
Re: Electric fan
71 rat did a good thread on a Chrsyler/ Jeep fan install, stock fan and it bolts rite into our stock shroud. I ended up buying his, so I will post up pics when I get it. The unit new sells for about 50, but I don't know the cfm's.
CST and I must have typing at the same time
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-05-2008 at 08:36 AM. |
10-05-2008, 08:42 AM | #7 |
Re: Electric fan
Thats what I was thinkin. I called my local dealer and they said it would be against the law for them to sell me a "recalled" part. I am not trying to buy the take-off fans, I want a brand new one.
Where did you get yours jaros44sr? Last edited by 1972CST; 10-05-2008 at 08:44 AM. |
10-05-2008, 09:28 AM | #8 | |
Re: Electric fan
Thread is titled...another cheap electric fan build
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-05-2008 at 09:37 AM. |
10-05-2008, 01:06 PM | #9 | ||
Future TOTM Winner
Re: Electric fan
I have seen formula that tell you how to calculate CFM using HP, A/C and radiator dimentions and material. I just can find them right now. Quote:
10-05-2008, 03:06 PM | #10 |
sharp as a marble
Re: Electric fan
with my last car, I started with one 16" fan. would not keep up with Fla. heat, and was very noisy. The dual 11" kept up on all the the very hot days, and was way quieter. I drive my 67 Chevelle, zz502, 700r4 ETC. to the Googuys show 2 years ago, and the heat index was 110. Driving from downtown Jacksonville to my home at the beach, the guage was a bit over 3/4. made me uncomfortable. I think that unless you are running a bunch of motor 2 11" or 12" would keep up just fine with Texas heat.
10-05-2008, 08:23 PM | #11 |
sharp as a marble
Re: Electric fan
hopefully here is a picture of what a mouth full 2 11" dual fans and a zz502 are in a 67 Chevelle
10-05-2008, 08:55 PM | #12 |
Re: Electric fan
Lets see the rest of the car!
10-05-2008, 10:25 PM | #13 |
Future TOTM Winner
Re: Electric fan
10-06-2008, 05:37 AM | #14 |
Re: Electric fan
Camaro fan, two position toggle (high/low), relay's, LED lights and a stock shroud.
Works great 75% of the time on low and is very quite, put it on high and you can watch the needle drop. Used a old school ignition resistor to provide the 4.5 volts on low. Fan draws 4.2 amps on low and 10.5 amps on high. |
10-06-2008, 09:46 AM | #15 |
Re: Electric fan
I have ran Flex-a-lite fans for years and have ahd good luck with them so far.
With my old 350 I used the "black magic" single electric fan w/ a clutch fan off the water pump. So the electric was only turned on during the summer heat wheeling the trails. Now with a BBC I use the dual 13.5" Flex-a-Lite: http://www.flex-a-lite.com/auto/html...-electric.html This fan is my only fan and I have had zero heat issues, works great. As for CFM I would not get any thing below 2500CFM.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
10-06-2008, 09:53 AM | #16 | |
Future TOTM Winner
Re: Electric fan
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 10-06-2008 at 09:54 AM. |
10-08-2008, 02:51 PM | #17 |
Sofa King. We, Todd, Ed.
Re: Electric fan
That Jeep fan set up is definitely the trick way to go. I got really lucky and found one at a swap meet for only 5 bucks! I was able to I.D. it thanks to this forum! I installed it on my 71 camper van (same shroud) and it works great. BUT, if you cant find a Jeep fan, here's a different idea I did to my Blazer and it works even better. http://67-72chevytrucks.com/vboard/s...d.php?t=282793
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
Thread Tools | |
Display Modes | |
