Old 10-08-2008, 03:57 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
1973 HEI conversion
My neighbor has a super clean 73 model and he has ask me to help him do an HEI convertion on it . Is it the same as the 67-72's ? He has the distributor and wires already . Is there any resister type wire that needs to be replaced or any tricks that are 73 specific that i need to know ? Thanks
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 10-08-2008, 06:34 AM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: 1973 HEI conversion
Replace the resistance wire that ran to your points system, from the fuseblock, with a 12guage wire and hook it up to the HEI "BAT" terminal. Thats it! Easy, Eh?
Albatrossian is offline   Reply With Quote
Old 10-08-2008, 09:01 AM   #3
manimal
manimal's Avatar
"OR" if he doesnt want to remove the resistance wire from the truck, You can runa 12g wire from a switched terminal on the fuse block to the dizzy.
I prefer to do it as mentioned above by Albatrossian,but that is on MY truck.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-08-2008, 01:58 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
O.K. i did my 67' the same way just checking to make sure there weren't major differences/changes betwwen 72 and 73-75 .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 10-08-2008, 10:01 PM   #5
Illgill
I am doing this today, I bought the Dist from summit for 89 and got the MSD 8.5 wires. it worked pretty good you have to crawl into the engine area to do it on my K20. Be careful withe the clips as the plastic is easy to break. Mine had a new cam put it made it a little harder to do.
73 Chevy K20 longbed 350 trans m20
Illgill is offline   Reply With Quote
Thread Tools
Display Modes
