Old 10-12-2008, 01:33 AM   #1
nrb's70gmc
nrb's70gmc's Avatar
c10 control arms on c20???
hello everyone, now i fully understand that this might be a stupid question lol but anyway, i have a c20 2wd and was wondering if the spindles will work with c10 control arms or if c20 ball joints will fit on c10 control arms,--just to be clear i want to keep the 8 lug but i wanted to update the control arms with some tubular units but i only see them listed for c10s, any ideas?? thanks
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 10-12-2008, 03:58 AM   #2
ak's-r-us
Re: c10 control arms on c20???
deleted
ak's-r-us is offline   Reply With Quote
Old 10-12-2008, 02:27 PM   #3
nrb's70gmc
nrb's70gmc's Avatar
thanks
Old 10-12-2008, 05:34 PM   #4
Ackattack
Ackattack's Avatar
Originally Posted by ak's-r-us View Post
yes, the c20 balljoints will fit the c10 arms.
ah....not in my experience....at least for the lower control arm.
I fubared my original C10 lower arm, and tried to use the control arm off my C20 parts truck, but the press fit hole on the C20 was larger. Don't know about the upper.
Ackattack is offline   Reply With Quote
Old 10-12-2008, 06:19 PM   #5
Arad68
Trucks N Tranzams
Arad68's Avatar
The ball joint and the cross shaft is bigger, at least the ends. I did this once thinking I could do the swap. Now I got two brand new lower 3/4 ton a - arms with ball joints sitting around collecting dust. The uppers are the same, at least on my 68.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 03-03-2009, 01:28 AM   #6
nrb's70gmc
nrb's70gmc's Avatar
ok here is another question, will c-20 rotors and other compnets fit on c-10 spindles?
Old 03-03-2009, 01:46 AM   #7
Arad68
Trucks N Tranzams
Arad68's Avatar
No. The spindle is different.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 09-13-2017, 05:56 PM   #8
nrb's70gmc
nrb's70gmc's Avatar
ok one last question
will c10 upper control arms bolt up to a c20 truck?
will (upper c20 balljoints) bolt on to c10 uppers?
i read that the crossshaft studs is 1/2in on c10's and 9/16th's on c20s?
i have brand new moog upper balljoints (1970/drum spindle) dont know if the balljoint bolt pattern is diffrent on disc (71-72 spindles)
thanks,
Old 11-08-2017, 03:44 PM   #9
nrb's70gmc
nrb's70gmc's Avatar
thanks,
i was going to ask this question again untill i found this. (mainly) will c10 upper arms bolt onto a c20? (using c20 upper balljoint?
Old 11-08-2017, 03:59 PM   #10
JustToxic
JustToxic's Avatar
Look for control arms and spindles for a '75 C20, the upper and lower control arms are the same on the 1/2 to the 3/4's in that body style. The control arms are the same size as the '67-72, but different ball joints. You can get tubular control arms for say a '75 C10/C20 but the ball joint will only fit the same year spindle. (make sense) I have a '67 C20 that I was going to switch all over to '75 parts but I just decided to make it a 4x4 instead. PM if you need more info.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 11-08-2017, 04:37 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
This is not correct.
3/4-ton lower a-arms have a bigger hole in the arm compared to the 1/2-ton lower a-arms.
Uppers are the same, and will accept either the 1/2-ton or 3/4-ton baljoint.
Keith
Convert to disc brakes.
Thread Tools
Display Modes
