Old 10-13-2008, 10:32 PM   #1
Redden05
Redden05's Avatar
350 V8 For Sale in Central PA
I have an 86 up (not sure of the exact year) 350 with the center bolt heads and one piece rear main seal. It runs good. The reason I am selling it is because it is not drilled for a fuel pump rod and I am using a mechanical fuel pump on my truck. So if you were going to put fuel injection, or use some kind of fuel pump other than a mechnical one, this would be a good engine for you. It has an Edelbrock intake on it which needs cleaned up. The bolt where the alternator bracket bolts on the intake has broken off flush with the intake and needs to be drilled out. The numbers on the block are as follows: The casting number on the rear is 10054727 and says that it is made in canada, the code in front of the passenger side head is K0408FBC, and the VIN below that number is CH4129162. I would like to get $350 for it and I am not shipping it. So pickup only. I live in Montgomery PA zip 17752. Thank You.
Redden05 is offline   Reply With Quote
Old 10-14-2008, 05:32 PM   #2
Redden05
Redden05's Avatar
Re: 350 V8 For Sale in Central PA
ttt
Old 10-15-2008, 04:29 PM   #3
Redden05
Redden05's Avatar
ttt
Old 10-15-2008, 11:36 PM   #4
Redden05
Redden05's Avatar
bump
Old 10-16-2008, 03:37 PM   #5
Redden05
Redden05's Avatar
bump
Old 10-17-2008, 03:32 PM   #6
Redden05
Redden05's Avatar
ttt
Old 10-20-2008, 04:38 PM   #7
Redden05
Redden05's Avatar
bump
Old 10-23-2008, 09:40 PM   #8
Redden05
Redden05's Avatar
bump
Old 10-26-2008, 03:47 PM   #9
Redden05
Redden05's Avatar
ttt
Old 10-27-2008, 11:03 PM   #10
Redden05
Redden05's Avatar
bump
Old 11-05-2008, 09:12 PM   #11
Redden05
Redden05's Avatar
bump
Old 11-10-2008, 05:40 PM   #12
Redden05
Redden05's Avatar
bump
Old 11-11-2008, 11:34 PM   #13
Redden05
Redden05's Avatar
This no longer has the intake on it. So $300 without the intake.
Thread Tools
Display Modes
