10-20-2008, 09:57 AM | #1 |
wing window.
my sons 1968 wing window bottom "pin" broke. Anyone fix one before? is it fixable? Any advice will be helpful Thanks, Gary
10-20-2008, 10:01 AM | #2 |
Re: wing window.
I used a flat head screw that I ground down to fit about 11 years ago and still works fine.
you never know what you can do until you have to undo something you have done! |
10-20-2008, 10:45 AM | #3 |
The Older Generation
Re: wing window.
You might check with some of the parts vendors, those rivets might be available. Something that size might even be available at your local hardware store. The only problem with the rivets is you would probably have to take the wing vent out to install them. LockDoc
10-20-2008, 02:38 PM | #4 | |
Re: wing window.
10-20-2008, 05:56 PM | #5 |
Re: wing window.
are you talking about the steel pin on the bottom of the frame inside the door? or the rivet up towards the top.If its the bottom pin it can be welded back on. If you need just one rivet we can send you one. Most all companies sell them.
10-20-2008, 06:00 PM | #6 |
Re: wing window.
I have a bunch of wing windows if you decide to replace the entire system....
I'll give you a good price since I don't need them all...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-20-2008, 09:20 PM | #7 |
Re: wing window.
Sorry guys, I was thinking top pivot. After reading the original post closer I finally figured out it's the bottom (as stated) one with the spring on it. It may be weldable but the frame is probably pretty weak right where you would need to weld it. I would consider replacing it with a good used one. LockDoc
10-20-2008, 09:23 PM | #8 |
Re: wing window.
If you have a local parts store that flys the CarQuest flag the should be able to get it for you.
10-20-2008, 09:26 PM | #9 |
Re: wing window.
these are what you are looking for right?
10-20-2008, 09:27 PM | #10 |
Re: wing window.
10-20-2008, 09:52 PM | #11 |
Re: wing window.
I'm thinking this is the piece Gary is talking about. LockDoc
10-20-2008, 10:53 PM | #12 |
Re: wing window.
i bought a wing glass kit from lmc. i had a man that works in our body shop to come by and take it out. he took it home with him a couple of days and dissasembled and reassembled it. works great now
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
Thread Tools | |
Display Modes | |
