Old 10-25-2008, 07:11 PM   #1
GOPAPA
GOPAPA's Avatar
I Could use some numbers on my belts I need
I have a 402 ci in my truck and it has the truck set up pulley system which is the alternator and powersteering pump on the right side .. ac on the left..
I go to napa and they give me belts 6 inches to long and then to short and was hoping that some of you might have the correct numbered belts and you could share them me .. I live some distance from town and fewer trips would be nice when trying to get the exact ones that fits.. for now I don't need the ac belt .
papa
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 10-25-2008, 07:15 PM   #2
screamin_eagle
screamin_eagle's Avatar
Re: I Could use some numbers on my belts I need
uh measure them
screamin_eagle is offline   Reply With Quote
Old 10-25-2008, 07:41 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Slide the pulleys to the short belt side of the adjuster.Then loop a string around it and tie it.Remove the string and use it as a length guide.This will give you inside diameter since the string is small.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-25-2008, 07:43 PM   #4
GOPAPA
GOPAPA's Avatar
Well , string I have wont work as it gets to deep in the grove and I havn't any rope that would be the size I need ,,got any ideas that might help me get the correct measurement?
I have only the belts that I have bought and brought home and I could cut one and then measure it but for $34 dollars for the two I was hoping some one by Monday morning might just have the same set up and help me out .. thx though ,, papa
Last edited by GOPAPA; 10-25-2008 at 07:54 PM. Reason: because after I posted I then read PanelDelands post
Old 10-25-2008, 08:09 PM   #5
cdowns
cdowns's Avatar
a piece of wire has always worked for me
Old 07-10-2010, 10:22 AM   #6
BERT306
BERT306's Avatar
I use the string method and then add 1-2 inches depending on how many pulleys you are going around, so if u are going around ps pump and crank, take string measurement plus 1. Crank, wp to alt add 2 inches. worked for me
BERT306 is offline   Reply With Quote
Thread Tools
Display Modes
