Old 05-10-2002, 09:50 AM   #1
goat455
Post dumb question- how to install radio?
Yes, it sounds like a dumb question, but dang , I'm new to the truck world and I can't figure it out. I bought a 71 truck radio for my 72 Cheyenne. I just can't figure out how to install it. If I go from the rear, the radio knob stems don't stick out far enough to fasten the nuts to attach it to the panel. On top of all this, there's not much space to work with with all those vent hoses in the way. Any suggestions?
goat455 is offline   Reply With Quote
Old 05-10-2002, 10:29 AM   #2
Randy70C-10
Randy70C-10's Avatar
Post
You wiil probably have to remove the vent ducts to install it. Not sure that I understand why you can't get the nuts on the stems though. They should be long enough.
Randy70C-10 is offline   Reply With Quote
Old 05-10-2002, 10:30 AM   #3
tom hand
CCRider
tom hand's Avatar
Post
The factory radios attach to the dash holes with some little funny cupped washer things. If you tried to use regular washers it would make the shaft too short to put the knobs on. Do you have these parts? If not put a request on the parts board and I am sure someone will sell you a set.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
[This message has been edited by tom hand (edited May 10, 2002).]
Olive Branch MS
tom hand is offline   Reply With Quote
Old 05-10-2002, 07:30 PM   #4
goat455
Post
Thanks for your tips guys. Tom, I understand what you're saying. I need those cupped whatever you call them. Does anyone have them? I'll post my wanted ad. Thanks.
Old 05-10-2002, 07:43 PM   #5
Rabid
Rabid's Avatar
Post
I've put a few radios in mine over the years. Each time I've had to at least move the heater controls out of the way.
72 C-10 Custom Deluxe
LWB, 2WD, 350
700r4, Holley 600
UNITED STATES ARMY - ALASKA
"Rangers lead the way!, Medics bring them back!"
Rabid is offline   Reply With Quote
Old 05-10-2002, 08:09 PM   #6
RodC
RodC's Avatar
Post
Just finished putting mine in.
I moved the heater controls and removed the ashtray assembly, gave me plenty of room:
Remove 2 screws holding heater controls in, unplug switch and move to right side.
Remove ash tray and bracket inside of dash (4 screws access from bottom.
The radio should bolt to the speaker, if the speaker bracket is not already in the truck put the speaker up in the dash first, (leave the bolt out of the back of the radio that bolts to the speaker) After you have the speaker up in (most are not bolted so you may have to hold it) Slide the radio up in, be careful of the heater duct hose.
Plug the radio in
Put the recessed washers in from the front of the dash, add the nuts to the front, reassemble everything else.
Good Luck, clean and lube those heater controls while you have them out.
BTW I had a hard time finding those recessed cups, bought a set off a board member here and I also bought a junker radio that has them on it. If you can't find them, let me know I may part with the extra set.
Do you have a set of orig. knobs?
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 05-11-2002, 12:02 AM   #7
goat455
Post
Rod, I need those recessed cups. Can you spare a couple? How much? Thanks.
[This message has been edited by goat455 (edited May 11, 2002).]
Old 05-11-2002, 03:20 PM   #8
RodC
RodC's Avatar
Post
If Fast68Chevy cant hook you up let me know. I only have one extra set.
Rod Childers
'71 C10 Stepside
Rod Childers
'71 C10 Stepside
Thread Tools
Display Modes
