Old 10-31-2008, 08:21 AM   #1
sourkraut
sourkraut's Avatar
Exhaust question? X, H pipe or neither?
I am soon going to be installing a new exhaust system. It will be used on a 350 and 5 speed setup. The exhaust will be 2.5" and have block hugger headers. My question is what have you guys found to be the best set up for performance? I have heard several different sides to each but most of all just smoothing out the exhaust tone(flow). I have used h pipes before and have noticed a big difference in of idle acceleration, whether it just smoothed everything out or added a little more performance I am not sure. I have never used a x pipe and have considered this but what to hear some of your options first. The proof is usually in the puddin' and just wanted to see if a x pipe is the way to go?
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 10-31-2008, 11:18 AM   #2
68_chop_top
68_chop_top's Avatar
Re: Exhaust question? X, H pipe or neither?
I don't have the reference but it was from a Chevy Hi Performance magazine or similiar but here is my 2 cents.
H pipes are good for bottom end torque and the X pipe is better for top end hp. Both are beneficial for performance.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 10-31-2008, 02:25 PM   #3
Ackattack
Ackattack's Avatar
I believe the X pipe is the best choice overall, however it's probably the most expensive too and can be a pain to install (ask how I know).
I got the pypes exhaust system for my 68 and it includes an X-pipe. I believe the magnaflow system does too. Both systems are stainless also.
The X pipe will change the exhaust tone too. On my vette, the stock exhaust uses an H-pipe and the magnaflow system I put on it uses and X....it has more of an "exotic" sound....but still real aggressive.
Ackattack is offline   Reply With Quote
Old 10-31-2008, 02:31 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
I just had new exhaust put on my truck. I had an H pipe and went to an X pipe and 50 series Flows( same mufflers only new). I like the X better, it just seemed to have a better tone and more responsive. just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-31-2008, 03:08 PM   #5
big_al_71
big_al_71's Avatar
I just re did the exhaust on my truck and did not do any of the two choices....My truck runs, sounds, idles, cruises and accelerates like a bat out of hell....Have had diferent set ups on all my vehicles and in all reality I never could tell any difference other than the sound. On a fuel injected vehicle "Maybe" just not in one of our buckets I dont feel it is necessary..
thats just my .25 cents worth
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-31-2008, 04:10 PM   #6
sourkraut
sourkraut's Avatar
Thanks for all your responses, I have not decided what to do yet. My main goal is to get the best over all performance and a cool sound! I am useing Magnaflow round mufflers for a different sound. I have always used Flowmasters and love their sound but figure I would go with something different this time around.
Old 10-31-2008, 04:14 PM   #7
LuckyHenriksen
LuckyHenriksen's Avatar
I just had exhaust put on mine, 2.5in. pipe, and it sounds kind of rattle-y, especially under hard acceleration. I want to add an x pipe because I think it will make the tone deeper.
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 10-31-2008, 04:28 PM   #8
sourkraut
sourkraut's Avatar
What kind of mufflers did you use?
Old 10-31-2008, 04:54 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would suggest you have the x 9r H pipes flanged and bolt them on.Usually they cause some interference when removing tranny or clutch.Might as well plan ahead as to have to redo them to replace a clutch.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-31-2008, 04:59 PM   #10
sourkraut
sourkraut's Avatar
Good idea I was planning on putting a locking flange like a turbo connection since it will be stainless. But did not think of doing it for later access to the tranny! You are pretty smucking fart! Don't say that backwards!
Old 11-01-2008, 03:40 AM   #11
LuckyHenriksen
Ya thats a good idea. I am running Cherry Bomb extremes, shaped like flowmasters with less stuff inside them
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
Thread Tools
Display Modes
