11-04-2008, 09:56 AM | #1 |
Wheel backspacing question
I have a 65 C-10 longbox step side. My wheels are currently 15 X 5.5 with a back space of 3.75, I want to put new rims on it. I see a lot of aftermarket rims with 4 - 4.5 backspace. will this work or will they rub on the backside? I was thinking about 17 X 8 rims and 265 55 17 rubber, will this fit back and front, and if I put disk brakes up front will this change anything?
11-04-2008, 11:23 AM | #2 | |
Re: Wheel backspacing question
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 11-04-2008 at 11:25 AM. |
11-06-2008, 09:58 AM | #3 |
thanks for the reply and the info, does anyone know if the disk brake kit will change the front end backspacing?
11-06-2008, 02:57 PM | #4 |
Yes, depending on the kit, back spacing will change. Typically, stock GM disc brake set-ups add 3/8" per side to the track width vs. drums. Aftermarket kits may or may not increase the track width depending on how custom the kit is.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-06-2008 at 02:58 PM. |
11-06-2008, 11:12 PM | #5 |
Resistance is Futile
You can run very deep backspace on these trucks before having an issue. It will hit the bed before having problems in the front. I have 5.25" and 5.5" backspacing on my 2 trucks.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-07-2008, 04:51 PM | #6 |
thanks for the help, it can be difficult to find info without this message board.
Thread Tools | |
Display Modes | |
