Old 11-06-2008, 12:18 AM   #1
yfz450_0569
rear sway bar questions
I would like to see rear sway bar set-ups, I'm building my own frame and have a parallel 4-link in the rear and now I need to decide what to do as for the sway bar. Any pics?
yfz450_0569 is offline   Reply With Quote
Old 11-06-2008, 10:42 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: rear sway bar questions
Can't help you with pics, but how about some of your frame?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-06-2008, 10:54 AM   #3
yfz450_0569
the link to my build forum is in my signature, you should see all my pictures there
now I need some info on how you set yours up or what I should go with if no pics
Old 11-06-2008, 12:42 PM   #4
7T7
Regular guy
7T7's Avatar
here's mine....
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 11-06-2008, 01:10 PM   #5
yfz450_0569
Originally Posted by 7T7 View Post
here's mine....
Thank you! I have yet seen anybod build their own sway bar, to me it looks really simple... I don't know much about them yet, maybe thats why. Do they require some special material for some of the stuff?
Old 11-06-2008, 08:39 PM   #6
7T7
Regular guy
7T7's Avatar
If you have a source to heat treat your stuff it's no big deal.
You can also piece one together using parts from the dirt track and asphalt guys.
If your wanting a splined arm set up that's the best way to go.
There is a way to build a torsion style sway bar and not use splines.
The one below is from Welders Series and is fairly easy to make.
'Frank'
77 Silverado
Old 11-06-2008, 09:45 PM   #7
yfz450_0569
any websites for this stuff? money's runnin short so i want to plan this out as best possible
Old 11-06-2008, 09:57 PM   #8
Ackattack
Ackattack's Avatar
7T7, Is that a rotor/caliper on the yoke of your rearend? Haven't seen that setup on a truck like ours....only on Rockwell 4x4 axles.
Ackattack is offline   Reply With Quote
Old 11-06-2008, 11:06 PM   #9
7T7
Regular guy
7T7's Avatar
Cheapest route is eBay.
Look up "NASCAR Sway Bar"
For new stuff, look at Speedway Engineering, Stockcar Products and Schroeder Racing Products.
'Frank'
77 Silverado
Old 11-06-2008, 11:08 PM   #10
7T7
Regular guy
7T7's Avatar
It's a street rod thing.
Emergency/ Parking brake.
'Frank'
77 Silverado
Old 11-06-2008, 11:29 PM   #11
Ackattack
Ackattack's Avatar
I see.....never seen it before.
Old 11-06-2008, 11:46 PM   #12
leftcoast66
leftcoast66's Avatar
Check out speedway. They do lots of dirt track stuff, and I think I remember seeing sway bar kits on there.
leftcoast66 is offline   Reply With Quote
Old 11-11-2008, 02:04 AM   #13
Big H
Big H's Avatar
The sway bar set up under 7T7's truck is a perfect rear sway bar for our trucks. Check out the links that these guys led you to and you will find different length bars with multiple resistance choices and the correct length lever assemblies. These systems go through the frame as you can see in the photo and therefore stay tucked up out of site and looking tight. Hey that rhymes...
Cleverly disguised as a responsible adult...
Big H is offline   Reply With Quote
Old 11-11-2008, 01:18 PM   #14
abadsvt
abadsvt's Avatar
Speedway is the place i am going to get my sway bars from. They have a good size collection of sway bar arms, spline sway bars solid and hollow with different size thickness. There is alot more though than just slapping on a sway bar and having it work perfect. Since it is for the rear suspension you most likely won't need a big sway bar. The quick rule of thumb is lower the RC (roll center) the larger or stronger sway bar you will need. The higher the RC is the smaller or weaker sway bar. So a parrelle 4 link could and most likely has a lower RC than a trianglated 4 link. Of course it depends on how they set up the rear suspension. Also the length of the sway bar arms will affect on how much stiffness the sway bar will have. The shorter the arms are the stiffer the sway bar will be and longer the arms of course makes them a little less stiff. There is tons of additional info to properly tune your suspension that is over the top confusing. My recommendation is go with a lighter sway bar and after the truck is all built then start tuning the sway bar. It is better to have a under sized sway bar than an oversized sway bar. Good luck
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-11-2008, 03:40 PM   #15
yfz450_0569
what's the difference between a sway bar and a torsion bar?
Old 11-13-2008, 07:16 PM   #16
71'tahoe
71'tahoe's Avatar
Hey guys,
A heads up on Speedway...there is two shops that go by "speedway" You have "speedway motors" and the other "speedway engineering" The one is alot of dirt track,streetrod,sprint car...They are in nebraska...The sway bars that you all talk of are on a different speedway site..I cant remember the site but it was smething like 1speedway.com or somehting like that..Ill do a search and see if I cant come up with some thing...Sway bars and torsion bars are kinda the same and completely different.
1) torsion bars like in old mopars,toyotas,nissan and mazda truck, act like front springs in the fact that they hold up the truck or car. A torsion bar uses a twist method to create spring rate. When the torsion bars are used as splined swaybars they do basicly the same thing using twist to deflect body roll, basicly like a normal sway bar does. If you ever messed around with old volks wagons then you know the front and rear suspensions used torsion bars much like sway bars,by requiring the twist method to raise or lower the car. Sprint cars actually use the splined torsion bars set up like swaybars to act as suspension. Hope this helps.
71'tahoe is offline   Reply With Quote
Thread Tools
Display Modes
