Old 11-09-2008, 09:04 PM   #1
bmrrwolfe
1970 C10
Underbed tank question
I found a new LMC underbed gas tank conversion kit for cheap, but it is for a 60-66 anyone know what the difference is between this kit and the 67-72 is and if this would fit with little or no modification?
bmrrwolfe is offline   Reply With Quote
Old 11-09-2008, 10:47 PM   #2
bmrrwolfe
1970 C10
Re: Underbed tank question
anyone know?
Old 11-10-2008, 07:33 AM   #3
wHATANERD
wHATANERD's Avatar
I don't know for sure, but looking at both LMC catalogs, the 60-66 has a Part # of 32-5924, and the 67-72 has a part # of 32-5925. Both tanks show to have the same dimentions 13"H x 19"W x 30"L. According to the dimention I would think it would fit under a 67 - 72, however being that the Part #'s are different the mounting could be different and might require fabrication to work. Hope this helps
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 11-10-2008, 10:47 AM   #4
70onB.A.D.'s
70onB.A.D.'s's Avatar
Hey man, i bought one for my 70 and I love it!! Plus we moved the filler neck to the top of the tank so i can the tank up threw my bed floor!! It is worth it if you get one!!
70onB.A.D.'s is offline   Reply With Quote
Old 11-10-2008, 01:26 PM   #5
70short
The sending unit on the old tanks is a 30 ohm. You need A 90 ohm sending unit for your application. Physical shape is the same.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 11-10-2008, 01:53 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by 70short View Post
the sending unit on the old tanks is a 30 ohm. You need a 90 ohm sending unit for your application. Physical shape is the same.
Gary
yup
leddzepp is offline   Reply With Quote
Old 11-10-2008, 02:09 PM   #7
bmrrwolfe
1970 C10
So the tank will fit exactly the same and just need a sending unit?
Thanks for the help!
Old 11-12-2008, 08:41 PM   #8
bmrrwolfe
1970 C10
I got the tank for $45 shipped to my door!
its a brand new LMC just there were 2 small dents in the top, and the float was missing from the sending unit (which i need to get a new sending unit anyways since its for a 60-66) but still an amazing price!
ill have to get some pictures when it comes, and probably start a build thread once i get a bit farther in the project.
Thread Tools
Display Modes
