Old 11-11-2008, 02:34 PM   #1
nyncompute
nyncompute's Avatar
Source for replacement tie rod?
I got to looking at my tie rod and its as crooked as a dogs hind leg. Anyone know of an online source for a replacement?. I see tie rod ends all over the net.
I have a 72 K-10. THX
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 11-11-2008, 04:25 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Source for replacement tie rod?
You're going to have to upgrade to a 73-76 setup. I looked all over the net when I had my 71 Blazer and nobody had the 71 set up...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-11-2008, 06:29 PM   #3
Rack Man
According to LMC's catalog all Tie Rod ends for 67-72 K-10's should be the same....Does yours have one or two adjustable ends?
If yours has two....I have a brand new quality set of MOOG tie rod ends that I could make you a good deal on...
I bought them for my truck and then wound up upgrading my Dana 44 to a later model with disk brakes and it had a different style tie rod....
Let me know if your interested.
Dan
Model# ES375L
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 11-11-2008, 07:01 PM   #4
72 CustomCamper
huh ???
Sounds like he's asking about the drag link, also called center link, not the tie rod ends...
Chuck
Old 11-11-2008, 08:46 PM   #5
nyncompute
nyncompute's Avatar
OK maybe I have my terminology screwy.. I need the rod between the ends. I assumed If they were called "tie rod ends" the thing in between (which is what I need) would be called a tie rod. If it's a drag link I stand corrected ..thanks.
Old 11-11-2008, 11:55 PM   #6
72 CustomCamper
huh ???
It's not correct, but you can use one from a 73-77 blazer, pickup or suburban that has a Dana 44. You will have to get the tie rod ends to match though. I wasn't able to find a replacement drag link for a 71-72 Dana 44...
Chuck
Old 11-11-2008, 11:56 PM   #7
Rack Man
No...your right...thats the tie rod....Most guys just assume that replacing a tie rod....means replacing the ends.....but you need to replace the actual tie rod itself!
I haven't seen them for sale new in any of the regular chevy truck supplier catalogs....best bet would be to ask around the classifides section or check out a local junk yard....
Hey now that I think about it....I have one that I took off my old Dana 44 Axle.....I scrapped the housing but saved the tie rod...It's off a 70 K-10.....has tie rod ends on both sides...it's straight...just needs cleaning and paint....I'd part with it real cheap!
Dan
Old 11-12-2008, 12:05 AM   #8
Rack Man
Huh?.....Drag links are for sale at nearly every parts house....for all 67-72 trucks...Granite they are the three piece design....not the original one piece style...but they are available
Here they are at LMC:
Old 11-12-2008, 02:07 AM   #9
milner
milner's Avatar
I believe he is talking about the part in the bottom pic between #1 and #2, the one that isn't highlighted. I checked at Napa for my 72 K20 which has one short and one long tie rod end. They only sell the short ones as replacements. They also have the bar but want $240 or so dollars for it. I bought the tie rod ends and my buddy has a race car chassis shop and we are making the bar ourselves with tube adaptors and tubing.
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
Thread Tools
Display Modes
