Old 11-12-2008, 10:08 AM   #1
67mater
67mater's Avatar
WTB power drum/drum proportioning valve
I am hoping to use the master and booster off my 72 donor, but it was setup for disc front. Anybody got a proportioning valve for power drum/drum?
Thanks!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 11-12-2008, 06:25 PM   #2
Bpokey
Bpokey's Avatar
Re: WTB power drum/drum proportioning valve
I have a power drum/drum setup I believe and I am looking for a power disc/drum. If you still have the disc/drum prop valve would you like to trade?
Bpokey is offline   Reply With Quote
Old 11-12-2008, 06:38 PM   #3
Bpokey
Bpokey's Avatar
Here is a pic of what I have.
Old 11-13-2008, 11:13 AM   #4
67mater
67mater's Avatar
I do have the disc/drum prop valve, but not sure on trade (wanted it for when I go to disc). Also, do you know if that's different that regualr drum/drum prop valve?
1967 K10
1967 Camaro
Old 11-13-2008, 11:48 AM   #5
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
67mater, The Master Cylinders are definetly different. The drum/drum M/C has 2 small fluid reseviors where the disk/drum M/C has a larger front/smaller back reseviour. The drum/drum setup has a fluid distrobution block (as in Bpokey's picture) whereas the disk/drum is a prop valve. I am swapping to a disk/drum setup so my drum/drum setup is for sale.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 11-13-2008, 01:29 PM   #6
67mater
67mater's Avatar
so what your saying is that the enitre getup needs to change to Drum/drum? Well, mayeb If that's the case, I'll hang onto my setup and put the manual drum/drum setup from the 67 on.
thanks guys!!
1967 K10
1967 Camaro
Old 11-14-2008, 01:34 AM   #7
Bpokey
Bpokey's Avatar
Thanks for the info myoldchevytruck. I guess the PO of my truck did a disc brake conversion and didn't bother to change anything but the rotor/calipers. Do you know the best route to finish the job? I have seen some trucks with the later model booster/master cylinder, is this better? 67mater, I hope all works out with your brake issue. Thanks.
Old 11-14-2008, 11:42 AM   #8
msgross
msgross's Avatar
Boosters only mater from 1/2ton to 3/4 ton etc...
correct in the MC and distro block for drums, I have one available as well if anyone needs it.
B-pokey, you need to find a disc/drum MC and prop valve to complete yours... How's it working right now? MC's are cheap at autozone but prop valves are a little higher.... i suggest just buying them new from there if you are looking to complete yours... Or if you feel that it works fine now then stick with it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-14-2008, 11:59 AM   #9
67mater
67mater's Avatar
So, can the MC and distblock original to my 67 3/4 ton drum/drum manual brake setup work with the booster from the 72 3/4 ton power disc/drum setup?
Aside from having power, I believe i need the booster to mount to the firewall as there are 4 bolts, not two for just the MC.
1967 K10
1967 Camaro
Old 11-14-2008, 09:13 PM   #10
Bpokey
Bpokey's Avatar
Thanks msgross. I am not sure how it drives yet. I have only driven it from the trailer to the garage and even then it had a stuck caliper. I had planned on the new MC and I guess I will just have to find a prop valve. I didn't know if the lines were different from disc to drum. Good to see all the veterans on here. I am at 12 years in the Navy on my way to 20. Thanks again.
Old 11-14-2008, 09:35 PM   #11
msgross
msgross's Avatar
might work? the booster also has brackets... power drums is better manual drums so go for it...
Be careful, I think you need to buy a new MC and prop valve to be safe. Hart_Rob just moved from Pensacola to NM but he still has trucks there. Good guy and a naval officer too...
The Garage:
Thread Tools
Display Modes
