Old 11-15-2008, 03:11 PM   #1
malexander44
brake problem
I'm having an issue with my brakes on my 63. I know that I need an alignment because my truck is pulling to the left. My problem is that when I brake hard it pulls to the right, not real bad, but still. When it rains or I drive through standing water and brake regularly it pulls really bad to the right.
Any suggestions?
Mark
malexander44 is offline   Reply With Quote
Old 11-15-2008, 04:29 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: brake problem
First of all, trucks '63 and earlier have manual adjusters (unless converted). You must adjust your brakes manually from time to time. I usually do mine when the pedal seems to be getting low.
So you are having two issue here: an alignment pull and a brake pull.
First thing to do is jack the front end up and set it safely on stands..remove wheels and drums and inspect brake linings. Brake soaked lining could cause a problem...If ok, and everything else is cool, then reinstall drums and wheels. Now time to adjust.
Using an adjustment tool or flat screwdriver, I usually tighten them all the way tight, then back off a couple of 'clicks'.
I adjust brakes so you have a slight drag when the wheel is spun.
Depress the brake pedal from time to time to center the shoes.
If done correctly and evenly, you should have a straight stopper.
I would first align the caster, camber and toe first, then go on to the brakes.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-15-2008, 07:36 PM   #3
2manyprojects
2manyprojects's Avatar
Re: brake problem
If the things ChiefRocka suggested don't help your problem. Rubber brake hoses that are old, or have been clamped off, can collapse internally and cause a brake pull. They may or may not look ok externally.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Thread Tools
Display Modes
