Old 11-26-2002, 10:39 PM   #1
minibike
minibike's Avatar
1"/3" drop
I have 1" drop coils on the front of my frame and 3" drop on the rear. Without the body on, it looks like it's got a fairly level stance. Does anyone have a picture of a truck with a 1/3 drop with all the parts on it and weighted down?
Thank,
Greg
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 11-27-2002, 10:24 AM   #2
crazy longhorn
Fabricate till you "puke"
From what i have seen on these trucks, it takes approx 2-2 1/2" more drop at the rear to make a level stance. I have hwat i would call "loosely" a 3/5 drop on the longhorn(no aftermarket parts), & she has 1" more height at the rear. Tire height is also a factor on the stance, but I would say you should have a fairly level stance. Sorry I cant help with the pics that you need to see tho.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-27-2002, 10:38 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
what kind of fuel tank do you have in your truck minibike?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-27-2002, 05:00 PM   #4
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
I'd like to know what tank that is also. It looks metal.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 11-27-2002, 06:40 PM   #5
minibike
minibike's Avatar
Appreciate the help longhorn...
The tank was custom made by a local boat builder. I have a fuel injected LT1, so needed to have a tank built around a Camaro in tank fuel pump. At $215, it was pretty reasonable.
Greg
69 SWB
LT1/4L60E
Old 11-27-2002, 10:55 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
From what i have been told, you will not see a change in height with a 1" drop spring. After 30 years, your old springs have sagged that much already. As for a level stance, it should be close with a 1-3 drop. Worst case is you add a spacer at the rear axle to fine tune it.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Thread Tools
Display Modes
