Old 11-17-2008, 06:51 PM   #1
84step
Warmup
Hey guys just recently gotting my lisence and been driving to school and around and I have to leave pretty early for school,and this time of year, up north it gets a little cold so I was wondering to anyone who lives in a colder climate how long do you give your truck to warmup? I gave mine about 5 min and everytime i would stop a light or traffic it would die on me and it really gets on my nerves.
"All Throttle No Bottle"
1984 C10 Stepper
84step is offline   Reply With Quote
Old 11-17-2008, 07:59 PM   #2
Ds86C10
2WD 4 Life
Ds86C10's Avatar
Re: Warmup
my truck sits for 10 hours while working at night and i let it warm up for 10 minutes at 3am and it hasnt stalled on me. i also just put in in new plugs and air filter and oil change too so im sure a fresh tune up wouldnt hurt.
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 11-17-2008, 10:25 PM   #3
chevymotocross
chevymotocross's Avatar
Re: Warmup
Make sure the choke is working right. Very important for cold weather running. What type of carburetor are you running?
chevymotocross is offline   Reply With Quote
Old 11-17-2008, 10:26 PM   #4
84step
Re: Warmup
I think the choke may be part of the problem, Iam running a 4bbl rochester quadrajet carb.
1984 C10 Stepper
Old 11-17-2008, 10:56 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Warmup
I rarely let mine warm up over a minute. But then again mine's fuel injected...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-17-2008, 11:38 PM   #6
78 Chevyrado
Re: Warmup
I let mine run on fast idle for about 20 seconds or so in warmer weather, and 2 to 3 minutes in colder weather. Of course, "cold" to me is around 30 degrees F.
78 Chevyrado is offline   Reply With Quote
Old 11-17-2008, 11:44 PM   #7
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Warmup
I never could get my quadrajet in my old Monte Carlo to act decent on cold mornings. It usually took a few miles for it to get normal.
-- Will
killthewabbit is offline   Reply With Quote
Old 11-17-2008, 11:48 PM   #8
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: Warmup
Lol. Dang i let mine warup for 20-30 minutes.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 11-17-2008, 11:57 PM   #9
D-Day
Live fast, die young
D-Day's Avatar
Re: Warmup
Depends on the temperature. I let mine run for about 5-10 minutes sometimes when it's really cold out, simply because I want the heater to be going good by then.
As long as I use the choke, I don't need more than 15-20 secs to warm up.
D-Day is offline   Reply With Quote
Old 11-18-2008, 01:09 AM   #10
lurch115
lurch115's Avatar
Re: Warmup
if you truck has an automatic choke on it as it warms up the cold idle SHOULD kick itself down once it reaches a certain point...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-18-2008, 02:35 AM   #11
shrtbx
Re: Warmup
I have noticed that my truck doesnt idle down. It pretty much stays the same the whole time. When i had my other engine in it would idle high then when i gave a poke on the gas it would idle down. Doesnt stall on me though when i take off though and it doesnt even seem to be idling to high. Do i need to adjust the idle on it or should i just leave it alone.
shrtbx is offline   Reply With Quote
Old 11-18-2008, 03:01 AM   #12
78 Chevyrado
Re: Warmup
If it's normal idle is fine then don't mess with that. There's another (seperate) set-screw somewhere for the fast idle. Maybe some rochester gurus can point you in the right direction. I have an edelbrock, my quadrabog took a crap and is long gone.
Old 11-18-2008, 03:30 AM   #13
shrtbx
Re: Warmup
I have an edelbrock 1406 though.
Old 11-18-2008, 01:46 PM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Warmup
I usually let mine warm up for about 5mins no major problems. Sounds like your choke is not working that well to me. I have eldebrock carbs on everything I own and no major problems.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-18-2008, 02:17 PM   #15
shrtbx
Re: Warmup
The confusing part is that it stays at the same idle the whole day as im driving and it doesnt sound like the the engine is idling too fast at all. I would atleast think it would eventually kickdown though. I just dont want to be dumping more gas than i have to at stops if the idle is too high.
Old 11-18-2008, 04:26 PM   #16
78 Chevyrado
Re: Warmup
If it never kicks down, then its likely the fast idle isn't functuioning. The fast idle cam is linked to the choke plate and will only function when the choke is closed (When the engine is "overnight" cold). Hold the throttle all the way open with your hand (engine off) and at the bottom of the part the throttle cable attatches to, there will be a screw facing you. That's the fast idle set screw and you cant get to it unless the throttle is all the way open. Do you give it any gas before you start it? to turn on the fast idle, you have to give it about a half pump with the pedal before you start it, then when it starts it will fast idle, then you tap the pedal again when you're ready to kick down to normal idle. Your choke may be out of adjustment, since they are directly linked.
Here's a pic of the idle screw on a #1406
Old 11-19-2008, 12:12 AM   #17
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Warmup
Edelbrock electric chokes are notorious for opening too fast. Adjust the choke to stay closed longer. I adjust mine for winter and summer times.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-19-2008, 12:46 AM   #18
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Warmup
mine warms up until i get good oil pressure then it's tire spinnin time
nothin like pissin off the neighbors at 5 am...(earlier then that i jsut done have the heart)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-19-2008, 01:47 AM   #19
asphaltburner
asphaltburner's Avatar
Re: Warmup
Yo! About a minute or two is proper. Set your choke at fully open, but about to close, when the engine is hot, and be sure the choke is nearly closed when cold. Tune the engine properly, and lube the choke mechanism. Todd.
asphaltburner is offline   Reply With Quote
Old 11-19-2008, 01:47 AM   #20
shrtbx
Re: Warmup
Nice. I dont give it gas. I turn the key and the motor fires right up. I will give it a pump haf a pump first like you said...thanks man.
Old 11-19-2008, 02:02 AM   #21
84step
Re: Warmup
thanks for the adivice guys. When I start it up I usually give it 1 pump and it starts but this morning i gave it about 10 min to warm up and it runs fine while cruising but when I stop or slow down the idle slows and it eventually shuts off, what would cause this?
1984 C10 Stepper
Old 11-19-2008, 04:01 AM   #22
gchemist
gchemist's Avatar
Re: Warmup
Edelbrock carbs are aluminum. In cold weather it just takes time to warm up. Icying is a problem too.
Old 11-19-2008, 02:19 PM   #23
shrtbx
Re: Warmup
Thanks. I did exactly what you instructed with the pedal and the carb did exactly what you said it would. Let it idle for a few minutes hit the gas again and it kicked down. I guess there are more to carburetors than i thought, seems like each one has its own lil deals..Thanks man.
Old 11-20-2008, 11:52 PM   #24
78 Chevyrado
Re: Warmup
Thread Tools
Display Modes
