Old 11-22-2008, 11:16 PM   #1
salrod00
salrod00's Avatar
swapping a 700r4 with a 350 transmission
Ok people help me please... i have a 85 SWB that i dropped a 350 TBI in. Well several months of driving it my drive and over drive went out on it. So now i dropped a 350 tranny in it. first time it leaked all the fluid from the front seal on the transmission. so now i put a new seal and i noticed that it is leaking from the converter . My question is do i use the converter that came with 350 tranny or what.. do i need to change anything else to get this thing on the road..thanks in advance
salrod00 is offline   Reply With Quote
Old 11-23-2008, 10:15 AM   #2
SSC's76
No No
SSC's76's Avatar
Re: swapping a 700r4 with a 350 transmission
Well for starters the 700r4 converter is different spline count so yeah the th350 converter is the one you need to use. The leak most likely isnt the seal or the converter but the pump bushing which requires you do replace that seal one more time but you need to take the front pump out to do it. The bushing kinda looks like a cam bearing sorta and gives the converter a surface to ride on.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 11-23-2008, 11:13 AM   #3
salrod00
salrod00's Avatar
ok so i do have the th350 converter with me already but when you say the pump bushing and taking out the front pump put. where is this at on the tranny. is it inside the fluid pan..???
Thread Tools
Display Modes
