Vin Numer Help
The door frame plate says Chevy 00 then under it.C1446A104529 The plate on the kick panel is Trim Blank Paint 555.Then under them. Could not make out the letters.But the number is 115.Then next to it CA blank no number.Thanks for any help.
1961 crewcab
Re: Vin Numer Help
VIN C1446A104529
Model Year 1966 Chassis 2 Wheel Drive Body Style Pickup Series 1/2-Ton Assembly Plant Atlanta, GA Sequential Number 104529 |
1961 crewcab
Re: Vin Numer Help
115 is for swb truck
1966 Factory Color Codes Code Description 500 Black 503 Light Green 505 Dark Green 507 Light Blue 508 Dark Blue 510 Turquoise 511 Dark Aqua 514 Red 516 Orange 519 Dark Yellow 521 White 522 Gray 523 Silver 525 Saddle 526 Ivory |
1961 crewcab
Re: Vin Numer Help
this is the only reference o CA that I found:
Transmissions Code Series Description Plant N N/A 4 Speed Muncie P N/A 4 Speed Muncie R N/A 4 Speed Saginaw W N/A 3, 4 Speed Warner Gear S N/A 3 Speed Saginaw M N/A 3 Speed OD Muncie C N/A Powerglide Cleveland T N/A Powerglide Toledo CA N/A 3 Speed Auto Hydramatic |
Re: Vin Numer Help
Thank you for the help.My paint code number is 555.But i do not see it listed.
Re: Vin Numer Help
The 00 might really be DD,double duty? The Saddle color actually had 2 codes 525 and 555, might have been a tu tone. All sequence numbers will start with 10, so it is the 4,529 truck built at Ga assembly plant that year. The VIN has no powertrain info, this would be on the build sheet or protecto-plate,which usually are missing after the 1st or 2nd owner sells.
Re: Vin Numer Help
Actually the production number starts with 100,000, which still makes it the 4,529th off the production line.
The plate on the driver's kick panel is affectionately known as the GVW Plate. It will show the Maximum GVW Rating of the truck...5,000lbs for 1/2 ton and 7,500lbs for 3/4 ton 2wd trucks. |
Thread Tools | |
Display Modes | |
