Old 12-02-2008, 07:55 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
My heater isnt working very well..
I drive the truck in my sig to school every moring...well 30* temps arent making me happy..the heater blows just a lil bit..but its not very hot at all, and its not alot of air comming out. whats my problemo?
thanks john!
John
1999 Toyota Tacoma 4x4
Old 12-02-2008, 08:05 PM   #2
463
463's Avatar
Re: My heater isnt working very well..
pull the heater hose's off and flush the heater core with water bottom first then the top till you get a clear stream of water. then reinstall the hoses. you may want to check your "T" stat (should have a 195f) and a good rad cap 15-16lbs and a good rad level. you could also make sure that the heater door is ajusted as to not let cold air in.
Trueman
463 is offline   Reply With Quote
Old 12-02-2008, 08:23 PM   #3
oldblue1968chevy
463 where is all of this located...I have no idea what or where your talking about these things are lol.....im very new to the world of trucks just barely 16 but have the tools space (time and patience run scarce sometimese lol)...but thanks!
John
Old 12-03-2008, 12:05 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Could be the fan too. I had to replace the brushes on the motor on mine. A little light oil on the bearings every 40 years or so works wonders too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 12-03-2008, 12:22 AM   #5
smoked68
smoked68's Avatar
I replaced my heater core last year and in the process cleaned out the ductwork. There was 40 years worth of leaves and what looked like a mutant rat nest...anyway heats great now and blows super...I'd start there.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 12-03-2008, 12:23 AM   #6
smoked68
smoked68's Avatar
OH and get you a Chiltons or Haynes book on our years. Advance auto etc. have em. Good luck.
Old 12-03-2008, 12:29 AM   #7
knsmodels
I make Models
knsmodels's Avatar
could be something as simple as low coolant level.......check that first.....
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 12-03-2008, 01:10 AM   #8
Indyuke
Like kns said. Check the simple things first. Check for enough water in the radiator. Check the heater hoses with the truck warmed up to see how warm they are. They should be too hot to touch.
When I first got my truck it did the same thing as yours. Barely warm air. Turns out someone had took the thermostat out and never put a new back in.
The cooling system worked great. So good in fact that the engine ran very cold. Could barely defog the window.
To find the thermostat just follow the top radiator hose over to the engine. Where it connects to the engine is the thermostat housing. Take off the thermostat housing and the thermostat will be sitting right in there. Some water will drain out when you take it apart, and you need a new gasket to put it back together. Just make sure you have a new gasket when you go to put it back together.
Indyuke is offline   Reply With Quote
Old 12-03-2008, 03:37 AM   #9
ERASER5
ERASER5's Avatar
A new fan motor is about $20 at AutoZone. P102 is the part no. I used.
If you change the fan motor, get a vacuum cleaner and some kind of smallish hose (about 1-1/2") and push into the housing and suck out the trash. This should help a lot. I pulled a big pile of trash out of mine.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-03-2008, 08:08 AM   #10
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
This is the heater/blower box. The hoses come in from the motor & out to the radiator or back to the motor if your radiator has been changed.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-03-2008, 09:44 AM   #11
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Sport/Truck View Post
This is the heater/blower box. The hoses come in from the motor & out to the radiator or back to the motor if your radiator has been changed. s/t
If I remember correctly, there's one bolt on passenger side bottom that's he// to get out. Anyone figured out how to get it out without having to remove the wheel well?
68gmsee is offline   Reply With Quote
Old 12-03-2008, 10:24 AM   #12
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I changed my heatercore & the hose bung on the old one was plugged solid with what looked like minerals (calcium?) It's as hot as an oven in my truck now. It is time/money well spend changing the heatercore & cleaning out the mung in the box. Dont forget to seal up where the bungs exit the heaterbox. There were foam seals there at one time, but they have usually turned to dust long ago. I havnt found an easy way to get that bottom bolt out. Mabe hire Vern Troyer for an hour?
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 12-03-2008, 09:37 PM   #13
oldblue1968chevy
alritey..well, I figured out what was wrong, you have to have the 'air/fan' on for it to blow hot...DUHH lol..but its still not comming out very hard..its hot..but not very breezy lol..
thanks!
John
Old 12-03-2008, 10:43 PM   #14
BarryB
BarryB's Avatar
Then you might want to pull your fan out and clean it out and to also check to make sure the motor isn't partialy seized. Pull the fan out and vacuum out the duct work what you can anyways.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-04-2008, 10:10 AM   #15
69long"n"low
69long"n"low's Avatar
If you do any thing with your cooling system just make sure you top it up with antifreeze or you'll crack your block.
- Josh
Im not white trash, I'm one step above that..... more like white clutter
69long"n"low is offline   Reply With Quote
Old 12-04-2008, 04:03 PM   #16
67mater
67mater's Avatar
WD-40 the switch at the fan control (behind face ) it often gets bound and won't kick to high. Again; simple first.
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 12-04-2008, 07:23 PM   #17
smoked68
smoked68's Avatar
I used a shop vac and a leaf blower to clean mine out...messy but it works. Blowin so hard now I have to wear my helmet when the heater is on...
Thread Tools
Display Modes
