Old 12-05-2008, 10:01 PM   #1
drewfever1020
how low can i go?
with 20's on my truck!
im wanting to order some new coils but i want my truck low, so how low can i got with 20's on my truck?
drewfever1020 is offline   Reply With Quote
Old 12-05-2008, 11:32 PM   #2
matthufham
Re: how low can i go?
you can lower it as much as a truck with little 15's as long as you use the right rim and tire.
matthufham is offline   Reply With Quote
Old 12-06-2008, 02:16 AM   #3
crazy longhorn
Fabricate till you "puke"
Figure about 3" drop on the front, & 5" rear drop on springs ......before you start cutting things up! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-06-2008, 11:01 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Not entirely true... depending on the size/height of your wheels and tires, you could run a 4.5/6 drop without being required to modify your frame and a-arms. Check out Early Classic Enterprises for some great parts and service. I'm planning on running a 4.5/6 on my truck with 20's.
You can also run bags and go lower, but will require a little more modification to your truck. Check out Suicide Doors and Air Ride Technologies for different bag setups. SD will offer great products at a lower price than ART.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-06-2008, 11:02 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I'd try to run some type of lowering spindle (2.5" drop) to help keep the factory specs on the front suspension.
-Nate
Old 12-06-2008, 11:35 PM   #6
sc340z
here's mine 5/6 with 20's
sc340z is offline   Reply With Quote
Thread Tools
Display Modes
