Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-06-2008, 04:32 PM   #1
mvfd70
mvfd70's Avatar
Shop insulation ??
I've got a 30' x 50' pole barn that I'm using for a shop. I've got a wall up to divide it into two parts. 30 x 20 garage and 30 x 30 shop. I'm wanting to insulate the 30 x 30 part. I've got a bunch of R-13 fiberglass paper faced rolls that I want to start with by putting them in the roof. I've been told to install a vapor barrier to control moisture. I plan on just leaving the insulation exposed cuz it's just a shop and I don't need to drywall the whole thing. Would it be better to install the vapor barrier between the metal roof and insulation or over the insulation where it would be exposed? Thanks
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 12-06-2008, 04:41 PM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Shop insulation ??
Check out this link...Good advice!!!
http://www.naturalhandyman.com/iip/i...infinsul2.html
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 12-06-2008, 05:07 PM   #3
mvfd70
mvfd70's Avatar
Well if I understood that correctly, I shouldn't need the plastic vapor barrier at all. Will the metal not sweat and cause moisture to get into the fiberglass?
Old 12-06-2008, 07:25 PM   #4
Arad68
Trucks N Tranzams
Arad68's Avatar
The plastic vapor barrier should be applied like this: from inside. Plastic barrier; isulation; then the roof. The vapor barrier protects the underside of the roof from rising moisture inside the garage. The condenstation is the moisture from inside the garage as the warm air rises from the floor to the roof. You would want the water to collect on the barrier not the insulation.
If you plan on heating your garage, even moderately, moisture will form. I hope this makes sense.
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 12-06-2008, 09:37 PM   #5
mvfd70
mvfd70's Avatar
Gotcha. The light bulb finally lit up. lol. That makes sense now.
Thread Tools
Display Modes
