12-10-2008, 10:12 AM | #1 |
Tearing apart my column
Well last night I was having problems with my turn signal lever wanting to go into the 'right' position. It was fine putting it in the 'left' position. I was almost home, needed to make a right turn and snapped something inside the column. Now it wont stay in either the 'right' or 'left' position and it is a little tricky to get my blinker to come on. I have to do it just right and hold it there til I make the turn. Anybody know what I broke that would be causing this? I have never torn my column apart, but I thought I remember someone saying there are some special tools needed. Anybody know what tools I will be needing? I searched and couldnt find any how to's, anybody know where I would be able to find one? thanks
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
12-10-2008, 10:40 AM | #2 |
Re: Tearing apart my column
Hey,
Simple fix but you'll need a tool alright. Here is a photo of what most likely broke. Here is a link to great instructions with photos on how to fix a whole column. You'll only need to do part of it though. http://elcaminocentral.com/article95.html
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
12-10-2008, 11:07 AM | #3 |
Oh, not sure if it matters but my truck is a 76 without tilt. will this ^ still help me? what is that part called?
12-10-2008, 12:00 PM | #4 |
Mine is a 76 as well with tilt but not much difference unless you are fixing bits deeper in the column.
You'll still need to remove the steering wheel and lock ring which goes over the bit in the photo and that is the piece that requires the tool. They don't cost much as the auto parts store. It's easier than you think. It's the turn signal switch assembly.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ Last edited by vtwinsport; 12-10-2008 at 12:04 PM. |
12-10-2008, 12:07 PM | #5 |
huh ???
The white piece in the pic is called a turn signal switch...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
12-10-2008, 12:23 PM | #6 |
Does anyone have any good places online to buy these tools? Im in Germany so im not sure if the places here would have anything like them.
12-10-2008, 07:43 PM | #7 |
Sb 400 club
you don't "need" the lock plate tool but it does make the removial easy. I have never use the too I just pus on the lock plate and remove the lock ring and it comes flying out. But It takes a bit of fighting and frustration to get it done this way.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
12-10-2008, 07:49 PM | #8 |
Plays with trucks
This place carries a lot of those type parts and tools, but they don't show very much on their web site.
www.natauto.com/ They do have an 800 number and they'd probably ship to an APO. I've always been happy with them...
Gary My Dad's Old Truck 1985 Last edited by 85gmcguy; 12-10-2008 at 07:52 PM. |
12-10-2008, 11:07 PM | #9 | |
12-10-2008, 11:14 PM | #10 |
Yo! 84 400 is correct,...you con't need a tool, but it does make the process, especially re-installation, easier. I've never used one on all the lockplates I've pulled. I just use a pair of pliers to push down on both sides of the lockplate and slip out the snapring. Installation is the reverse.
And, yes, the turn signal switch return spring is what's broken,...you'll need to replace the turn signal switch assembly with it's plug. Loosen the steering column bolts below the dash, and the channel that the wires run through below the steering column, and this process is easy. Just did my '78's recently. Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK! |
Thread Tools | |
Display Modes | |
