12-12-2008, 12:50 PM | #1 |
Another Christmas Replacing a Clutch.
It was 4 years ago I did this, and the Trans is coming out again. The Pilot, Throwout or God forbid, the input shaft is buzzing like a can of bees playing golf.
I guess, while I'm under there, I'll replace the flywheel this time, Cab mounts, oil pan gasket and rear seal, along with the clutch kit. Dear Santa: Bring me all this stuff and some warmer weather. I've been (mostly) good all year. - Dave PS: What's the best/easiest way to get the pilot bushing out?
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
12-12-2008, 03:35 PM | #2 | |
Re: Another Christmas Replacing a Clutch.
My Truck's not leaking its marking its territory! |
12-12-2008, 03:46 PM | #3 | |
12-12-2008, 03:55 PM | #4 |
grease and a punch that fits in side the pilot bushing.
completely fill the cavity behind the bushing with grease, insert the punch and hit it with a hammer, bushing will pop right out
CHEVY ONLY |
12-12-2008, 06:30 PM | #5 |
Sb 400 club
autozone will let you barrow a pilot bushing puller for a deposit that you get back when returned. this tool makes the removal a snap. It only took me seconds to pull mine.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
12-12-2008, 07:08 PM | #6 |
Packing it solid with grease as suggested by joe231 is the only way I have ever done it. Anything that is cylindrical and of the same diameter as the pilot bearing's inside diameter will work....bolt, wooden dowel, etc.
As it slides out, you may have to add more grease. |
12-12-2008, 09:36 PM | #7 |
I got a little cone shaped bolt with with a grease zerk on the end of it. Just tap it into the bushing so the threads can grab and crank on it with a wrench a few times then you take a grease gun and pump it full of grease and it pops right out.
I got it from the local auto parts place.
Its no disgrace being poor. Its just inconvenient. |
12-12-2008, 09:49 PM | #8 |
One shot, one kill.
33 years of Chevy mechanic. Grease and a dowl that fits the old pilot hole and a hammer, pops right out. A note to the wise, DO NOT under ANY circumstances use a pilot bearing with rollers inside!!! Use the cintered brass bushing!!! 10 years as 18 wheeler driver. Clutches are for starting and stopping and going backwards. After you get her rolling you don't need the clutch. Learn how to read a tach and a speedo and you can slap that stick all over the place all day long without grinding. During my build I replaced the clutch at 465,000 miles!!!
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
12-17-2008, 01:26 PM | #9 |
Thanks for the pilot advice guys. I'll let you know how this goes. Gonna attempt it this weekend.
It should be warmer, about 17º expected by then. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club Last edited by wedgemon; 12-17-2008 at 01:26 PM. |
12-17-2008, 01:29 PM | #10 |
Double 6's
Sorry....this is funny as hell!!!! Last edited by badblu97; 12-17-2008 at 01:30 PM. |
01-10-2009, 02:10 PM | #11 | |
BTW - Still sitting outside the garage. I got lazy with two weeks off over the holidays. Probably going in the garage this weekend. - Dave
01-10-2009, 04:44 PM | #12 |
One shot, one kill.
Dave,rememebr what I posted earlier about pilot bearing use. I hope it dosen't have a roller bearing one in it now. If thats the noise you might be replacing the input gear.
01-10-2009, 07:40 PM | #13 |
One shot, one kill.
Wedge: If the new clutch kit comes with the roller bearing Don't use it. I'll give you the sintered brass one. I have several of them laying around. Let me know, jim
Thread Tools | |
Display Modes | |
