Old 12-18-2008, 01:11 PM   #1
Daggar
Daggar's Avatar
No power to dash, ignition, accessories - 1987 Suburban
Forgive me if the answer is posted elsewhere on herw but the search function does not like my PDA.
This morning I went out and it was about -25 degrees c outside. Went to start the Suburban and it turned and fired ran for 5 seconds and then I lost power to the dash and the engine died. Now I have no power to the ignition or dash power locks or rear window. All I seem to have is a working dome light and the horn and key buzzer works. I checked all the fuses under the dash,and the wires running to the starter I did not see any burned out wires and the fuses all tested good with my voltmeter. Is there any hidden fuses in the engine bay that I might be missing?
Any help would be great as I really need my truck for work.
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options
1967 Chevrolet C10 Longbox Stepside - Restored
1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled
1987 GMC Suburban 1500 - Now some retired guy's trailer hauler
1992 Lumina Z34 - I'll miss that PITA
Daggar is offline   Reply With Quote
Old 12-18-2008, 03:01 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: No power to dash, ignition, accessories - 1987 Suburban
small wire running from starter to fire wall junction just to the P/s of the brake master cylinder is a fuseible link wire it's most likely fried out. About 6-8 inches up from the starter cut it and replace it with another fusible link. That could vaery well be the source of your problem.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-25-2008, 09:13 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
It might possibly be the plug between the steering column and the wiring harness, Real long ans skinny attached to the column. Might be coming apart I've had that happen once.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Thread Tools
Display Modes
