12-21-2008, 01:30 AM | #1 |
header decisions
ok trucks been in my friends shop since thansgiving. havent been able to work on it for couple weeks now.. driver cab corner is in just have to do some body work to it like putting the filler on.. i have other corner to do still. along with both inner and outer rockers and cab supports.. i have been thinkin... i have flowmaster original 40s on it now. and i have stock exhaust manifolds on it now. since the truck isnt in driving state right now i have thought about doing a manifold swap to headers. which kind should i install... any ideas?? remember i am only 17 and not made of money for the high high doller equiptment...
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
12-21-2008, 01:37 AM | #2 |
Re: header descisions
Probably the ones that dont cost a lot...
12-21-2008, 01:39 AM | #3 |
i know that but i heard that like flowtech the collector rusts out... so not sure what to decide...can u guys tell me what ya got and how ya like them? i am interested in the stainless steel ones.. since im getting chrome inner fenders... if i have to save up to get expensive kinds i will...
12-21-2008, 05:31 AM | #4 |
Because I have a manual transmission, I chose the stainless steel shorties by Summit and have been pleased with them. I would probably go with the ceramic coated shorties by Summit if I had it to do again since SS will discolor more easily (especially on a new motor) than I anticipated. I completed the exhaust system with glass paks but wish I had gone with something a little quieter since my exhaust exits in front of the rear wheel (right behind my ear). Good luck!
Jim (1967 Stepside with recent GM crate motor conversion) |
12-21-2008, 02:08 PM | #5 | |
Like a Rock!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
12-21-2008, 02:30 PM | #6 |
I am using the cheap Hooker Comp headers, only cost like 180ish and they fit great, and havent fallen apart yet, even though I only have like maybe 100 miles on them =]
Summit also makes a cheap set |
12-21-2008, 02:45 PM | #7 |
12-21-2008, 02:54 PM | #8 |
the boat guy
i got flowtech because im cheap, if i didnt work at a driveshaft shop, it would have cost alot more. had to move engine back 3" and cut massive chunks of a-arm off, beat the headers and make new brake lines. and less than a year their is rust on the ceramic coating.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-21-2008, 03:07 PM | #9 |
you modified it that much just to get crappy headers to fit?>
12-21-2008, 03:16 PM | #10 |
Hooker comps here too. 2500+ miles. Only changed gaskets once (last weekend), and they fit perfect. Used ceramic header paint, 1/4 of which has flaked off now. Auto trans here tho.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
12-21-2008, 08:33 PM | #11 |
oh ok i still havent made up my mind yet.. i just want something i dont have to take off and put a new set on because i know ppl that work at autozone and they said they see a lot of flow tech headers coming back because the collector rusts out....
12-21-2008, 09:16 PM | #12 |
Buy a new set of headers, sandblast them, and paint them with VHT paint and they will last several years.That's what I did before I started using coated headers.
12-21-2008, 09:19 PM | #13 |
I will be taking mine off and selling them in the next couple of months, so if any body wants them......
12-21-2008, 10:44 PM | #14 |
I've got Hookers' as well ,they fit good ,and work good.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
12-21-2008, 10:48 PM | #15 |
The LuvShack Garage
Hedman "Elites" Here, perfect fit, 3/4 length, coated, ball
flanges, and under $300 to my door, worth every extra $.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-21-2008, 11:21 PM | #16 |
I got the regular uncoated shorty hedmans this time last year. They are just now rusting. The ball and flange is not much better than a regular collector over time so I welded mine to the headpipes.
Next time I think I'll go with Hookers...they seem to have the best fit around. Flowtechs sound like a really bad idea afterr reading that post!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 12-22-2008 at 01:19 AM. |
12-21-2008, 11:24 PM | #17 |
My '89 had Flowtechs that were @ 5 years old & still looked & sounded good when I sold the truck last spring.
12-21-2008, 11:41 PM | #18 | |
the boat guy
i assumed a company that was doing buisness on a national level would have an acceptable product.
12-21-2008, 11:56 PM | #19 |
Re: header decisions
Ya you would think, but then you could have bought an even cheaper header that didnt require you to hack everything up
12-22-2008, 12:07 AM | #20 |
Resident of Here
Shorty headers are much easier to install I believe.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-22-2008, 12:23 AM | #21 |
just my 2 cents, but I installed the thorley headers on my 4 speed, 4 wheel drive Blazer this weekend and I couldn't be happier with the fit. They are pricier than some of the others but from what I here, they last a long time.
http://store.summitracing.com/partde...5&autoview=sku |
12-22-2008, 12:36 AM | #22 |
Definitely nice, but the price scares me away. I guess you get what you pay for right?
12-24-2008, 06:57 AM | #23 |
Summit ceramic shorties - part # G9060-1; costs about $180.
Good luck and Happy Holidays Jim ('67 stepside with 350 v-8 conversion and 3-spd manual tranny) |
Thread Tools | |
Display Modes | |
