12-27-2008, 06:31 PM | #1 |
Oil pump & oil pan
Will the oil pan clear the front crossmember without moving the engine?
I may have to change my oil pump and I want to know if I can do this without lifting the engine up to clear everything? The pressure has dropped to 25# when cold with 10-30 oil and it use to read 35 to 45 in the cold mornings. Yes it has a lot of miles but I am the only owner since new and it is serviced regularly, 78 350/350. Do the sending units go bad? when the engine is up to operating temp. the pressure is even lower 25# at speed in third gear.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
12-27-2008, 07:49 PM | #2 |
Re: Oil pump & oil pan
With a 350 in a 2wd 73-87, you can take the pan off without moving the engine. But you will have to rotate the crankshaft to a certain point so the pan clears the crank throws. I did it in my 77, 78 and 87. I think only a 400 can't be done like that.
12-27-2008, 08:09 PM | #3 |
One shot, one kill.
Solid: Sending units do fail!! Check pressure with a mechanical guage before condeming the pump. Mine is over 465,000 miles and still holds 50 psi at 60 mph & idles warm at about 30. I run Mobile1 20-50 all year round. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
12-27-2008, 08:57 PM | #4 |
the pollock
yeah i jsut replaced today a sending unit
they do go bad and if it's an origional 78 unit.. it' probably time to get some love and spend 20 bucks
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
12-27-2008, 09:11 PM | #5 |
How many different sending units are there?
Does any one have tha right part number? If yours has 450+ I feel like mine is just half way there with 200K. The only thing I have changed is the water pump(2) and 2 feel pumps and 2 transmissions. Valve seals are toast and oil consumption is going up! I think it is good for another 25 years!!
12-27-2008, 09:34 PM | #6 |
One shot, one kill.
I have changed 2 water pumps 1 fuel pump. Resealed the valves once, overhauled the Q-jet 4 times and replaced the clutch when I overhauled the body. I can't remember the last time it got a tune up and ssomewhere near 1500 oil changes, LOL, jim
12-27-2008, 11:27 PM | #7 |
the pollock
theres "one style" for the oil pressure sending unit it just a lil different from different manufactures...
and they are a noticeably different for aftermarket gauges now if you go down to a napa or carquest (where people have a higher chance of knowing what motor actually is!) instead of an autozone and tell them you have a gen I 350 and you need a oil pressure sendign unit they'll usually just walk back and be like "hey i knew i had a few back there" and blow dust off the box if you go to auto zone.. watch the over peirced/dyed hair teenage boy who hates his father ask you a bunch of questions about your truck "ya sure it's not a honda mannn?" and then get you the wrong part.. orrr.. u can follow this linky.... http://www.autozone.com/R,431903/veh...ductDetail.htm
12-27-2008, 11:51 PM | #8 |
I think the dummy light- senders are a lot bigger than the guage-sender IIRC.
12-28-2008, 12:20 AM | #9 |
the pollock
well that's pretty much the same one i put in..
my chev dosent have a puter/caution lighting or original motor.. i just pulled the bulbs and pay attention to my gauges.. stock gauges/ stock parts/ works good fer me =-) but the link igave was the same one i put in today.. it squeesed in there behind a high rise but it works =-)
Thread Tools | |
Display Modes | |
